Minimum system requirements
Q: What are the system requirements for running VirtualDJ?
Below are the recommended system requirements for running VirtualDJ:
Ideally, your computer should meet and preferably exceed the recommended requirements.
MS Windows
Supported Operating systems
- Windows 7*
- Windows 8*
- Windows 8.1*
- Windows 10
- Windows 11
Recommended Hardware requirements
- Intel® i5™, AMD Ryzen 7 or better
- Windows 10 or newer
- Multi-channel soundcard
- 8 GB RAM or more
Additional for Video mixing
- AMD™ or NVIDIA® video card
- Dual-screen output for second monitor
Additional for Stems isolation
- Windows 10 64-bit
- NVIDIA® video card (950 or above)
macOS
- OS X v.10.11 (El Capitan)
- OS X v.10.12 (Sierra)
- OS X v.10.13 (High Sierra)
- OS X v.10.14 (Mojave)
- OS X v.10.15 (Catalina)
- macOS 11 (Big Sur)
- macOS 12 (Monterey)
- Intel® i5™ or better, or M1 processor
- macOS 11 or newer
- 8 GB RAM or more
- AMD™ or NVIDIA® video card or M1 processor
- Mac OS X v.10.14 or newer
- AMD® video card or M1 processor
* VirtualDJ 2021 is not supported by older Operating Systems. VirtualDJ 2020 can still be used and downloaded here.
Older Operating Systems
Windows XP / Windows Vista
Windows XP and Windows Vista are only supported up to VirtualDJ 2018 build 4787 (download)
macOS X 10.7
macOS X 10.7 is only supported up to VirtualDJ 2018 build 4918 (download)
macOS X 10.8
macOS X 10.8 is only supported up to VirtualDJ 2020 build 5630 (download)
macOS X 10.9
macOS X 10.9 is only supported up to VirtualDJ 2021 build 6503 (download)
macOS X 10.10
macOS X 10.10 is only supported up to VirtualDJ 2021 build 6878 (download)
Please be aware that it is highly recommended to upgrade to a more recent operating system; as these are no longer supported there is a high risk of malware. New controllers, features and updates are also not available for these older builds.
Notes:
- Some older DJ hardware may not be compatible with the latest available Operating systems. Before upgrading, you should check the manufacturer's websites to ensure that all hardware that you will be using (Sound cards, MIDI controllers, etc.) is compatible.
- Make sure you have the latest version/build of VirtualDJ http://www.virtualdj.com/download/index.html
Related Topics:
FAQ Can I install VirtualDJ on my Apple iPhone, iPad, iPod or Android?
FAQ Does VirtualDJ work on Linux?
Navigation
