Plugins_SDKv8_Example3
Video FX Plugin using SDK v8
Here is an example to start developping a plugin "MyPlugin8". We use the class "CMyPlugin8" to define our object but you can use what you want. The file "Main.cpp" is the caller of your object "CMyPlugin8" and is the entry point to communicate with VirtualDJ.
For this example, you need to include the following files from the SDK v8 in your project: vdjPlugin8.h (basic common base-class for all plugins) and vdjVideo8.h (base classes for all Video plugins)
You can download the Visual C++ project for this project on a PC. It will generate a .dll file
MyPlugin8.h:
#ifndef MYPLUGIN8_H
#define MYPLUGIN8_H
#include "vdjVideo8.h"
#if (defined(VDJ_WIN64))
#include <d3d11.h>
#pragma comment(lib, "d3d11.lib")
#include <atlbase.h> //we use atl for the CComPtr Smart pointer, but this is optional
#elif (defined(VDJ_WIN))
#define DIRECT3D_VERSION 0x9000
#include <d3dx9.h>
#pragma comment(lib, "d3dx9.lib")
#elif (defined(VDJ_MAC))
#include <OpenGL/OpenGL.h> // you have to import OpenGL.framework in the XCode project
typedef unsigned long D3DCOLOR; // To use the same approach as Microsoft Direct3D
#define D3DCOLOR_RGBA(r,g,b,a) ((D3DCOLOR)(((((a)&0xFF)<<24)|(((r)&0xFF)<<16)|((g)&0xFF)<<8)|((b)&0xFF)))
#define glColorD3D(d3dcolor) glColor4ub((d3dcolor>>16)&255, (d3dcolor>>8)&255, d3dcolor&255, (d3dcolor>>24)&255 )
#endif
// Some colors
const D3DCOLOR white = D3DCOLOR_RGBA(255,255,255,255);
const D3DCOLOR black = D3DCOLOR_RGBA(0,0,0,255);
const D3DCOLOR red = D3DCOLOR_RGBA(255,0,0,255);
const D3DCOLOR green = D3DCOLOR_RGBA(0,255,0,255);
const D3DCOLOR blue = D3DCOLOR_RGBA(0,0,255,255);
const D3DCOLOR translucide_black = D3DCOLOR_RGBA(0,0,0,120);
class CMyPlugin8 : public IVdjPluginVideoFx8
public:
HRESULT VDJ_API OnLoad();
HRESULT VDJ_API OnGetPluginInfo(TVdjPluginInfo8 *infos);
ULONG VDJ_API Release();
HRESULT VDJ_API OnDeviceInit();
HRESULT VDJ_API OnDeviceClose();
HRESULT VDJ_API OnStart();
HRESULT VDJ_API OnStop();
HRESULT VDJ_API OnDraw();
private:
HRESULT OnVideoResize(int VidWidth, int VidHeight);
int VideoWidth = 0;
int VideoHeight = 0;
ID3D11Device* D3DDevice = nullptr;
IDirect3DDevice9* D3DDevice = nullptr;
IDirect3DTexture9* D3DTexture = nullptr;
IDirect3DSurface9* D3DSurface = nullptr;
CGLContextObj glContext = 0;
GLuint GLTexture = 0;
#endif
#endif
MyPlugin8.cpp:
#include "MyPlugin8.h"
#if (defined(VDJ_WIN))
#ifndef SAFE_RELEASE
#define SAFE_RELEASE(p) { if (p) { (p)->Release(); (p)=NULL; } }
#endif
#endif
HRESULT VDJ_API CMyPlugin8::OnLoad()
// ADD YOUR CODE HERE WHEN THE PLUGIN IS CALLED
return S_OK;
HRESULT VDJ_API CMyPlugin8::OnGetPluginInfo(TVdjPluginInfo8 *infos)
infos->PluginName = "MyPlugin8";
infos->Author = "Atomix Productions";
infos->Description = "My first VirtualDJ 8 plugin";
infos->Version = "1.0";
infos->Flags = 0x00; // VDJFLAG_PROCESSLAST if you want to ensure that all other effects are processed first
infos->Bitmap = NULL;
return S_OK;
ULONG VDJ_API CMyPlugin8::Release()
// ADD YOUR CODE HERE WHEN THE PLUGIN IS RELEASED
delete this;
return 0;
HRESULT VDJ_API CMyPlugin8::OnDeviceInit()
HRESULT hr;
hr = GetDevice(VdjVideoEngineDirectX11, (void**) &D3DDevice); //GetDevice doesn't AddRef(), so we don't need to release D3DDevice later
if (hr!=S_OK || D3DDevice==nullptr)
return S_FALSE;
hr = GetDevice(VdjVideoEngineDirectX9, (void**) &D3DDevice); //GetDevice doesn't AddRef(), so we don't need to release D3DDevice later
return S_FALSE;
glContext = CGLGetCurrentContext();
#endif
// Size of the Video Window
VideoWidth = width;
VideoHeight = height;
return S_OK;
HRESULT VDJ_API CMyPlugin8::OnDeviceClose()
D3DDevice = nullptr; //can no longer be used when device closed
glContext = 0;
#endif
return S_OK;
HRESULT VDJ_API CMyPlugin8::OnStart()
return S_OK;
HRESULT VDJ_API CMyPlugin8::OnStop()
return S_OK;
HRESULT VDJ_API CMyPlugin8::OnDraw()
HRESULT hr;
TVertex *vertices = nullptr;
if (VideoWidth!=width || VideoHeight!=height)
hr = OnVideoResize(width,height);
ID3D11ShaderResourceView* textureView = nullptr; //GetTexture doesn't AddRef, so doesn't need to be released
hr = GetTexture(VdjVideoEngineDirectX11, (void **) & textureView, &vertices);
CComPtr<ID3D11DeviceContext> devContext; //use Smart pointer to automatically release pointer and prevent memory leak
D3DDevice->GetImmediateContext(&devContext.p);
//some other interfaces that are often useful to get when dealing with DX11
CComPtr<ID3D11Resource> textureResource;
textureView->GetResource(&textureResource);
if (!textureResource)
return E_FAIL;
CComPtr<ID3D11Texture2D> texture;
textureResource->QueryInterface<ID3D11Texture2D>(&texture);
if (!texture)
return E_FAIL;
D3D11_TEXTURE2D_DESC textureDesc;
texture->GetDesc(&textureDesc);
hr = GetTexture(VdjVideoEngineDirectX9, (void **) &D3DTexture, &vertices);
hr = D3DTexture->GetSurfaceLevel(0, &D3DSurface);
SAFE_RELEASE(D3DTexture);
SAFE_RELEASE(D3DSurface);
hr = GetTexture(VdjVideoEngineOpenGL, (void **) &GLTexture, &vertices);
// glEnable(GL_TEXTURE_RECTANGLE_EXT);
// glBindTexture(GL_TEXTURE_RECTANGLE_EXT, GLTexture);
// glBegin(GL_TRIANGLE_STRIP);
//for(int j=0;j<4;j++)
//glColorD3D(vertices[j].color);
//glTexCoord2f(vertices[j].tu, vertices[j].tv);
//glVertex3f(vertices[j].position.x, vertices[j].position.y, vertices[j].position.z);
//glEnd();
#endif
hr = DrawDeck();
return S_OK;
HRESULT CMyPlugin8::OnVideoResize(int VidWidth, int VidHeight)
// OnDeviceClose();
// OnDeviceInit();
VideoWidth = width;
return S_OK;
Main.cpp:
HRESULT VDJ_API DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject)
if (memcmp(&rclsid,&CLSID_VdjPlugin8,sizeof(GUID))==0 && memcmp(&riid,& IID_IVdjPluginVideoFx8,sizeof(GUID))==0)
*ppObject=new CMyPlugin8();
else
return CLASS_E_CLASSNOTAVAILABLE;
return NO_ERROR;
