VDJScript Examples
VirtualDJ Script Examples
- RGB LEDs
- Assign different actions for the same button or knob on each side of a dual-deck controller
- Use a combination of buttons to trigger two different actions
Execute different action on click and different on double-click (for controllers)
var 'double' ? set 'double' 0 & repeat_stop 'myrep' & device_side 'left' ? deck left clone_deck right : deck right clone_deck left : set 'double' 1 & repeat_start 'myrep' 400ms 1 & load & set 'double' 0
The script uses a timer and waits for 400ms to see if a second click (push) comes.
If not it loads the track on deck, if Yes, it clones the deck to the opposite side.
Script added from Djdad
*Edit* This script has now been simplified with the action/query 'doubleclick ? '
doubleclick ? device_side 'left' ? deck left clone_deck right : deck right clone_deck left : load
Automix doesn't 0 pitch onload (custom button)
var_equal "AMpWA" 0 ? off & set "AMpWA" 1 & repeat_start_instant "AMpitcher" 33ms & load_pulse ? repeat_start_instant "pitchRem" 1000ms 1 & pitch & param_cast & set "AMpitch" : get_var "AMpitch" & param_cast & pitch : blink & set "AMpWA" 0 & repeat_stop "AMpitcher"
Explained Here
Script added from Locodog
Button to collapse all folders (for controllers or keyboard)
repeat_stop 'rsi_CollapseFolders' & browser_window 'folders' & browser_scroll 'bottom' & param_equal get_browsed_folder_tab 0 ? set '$BRPreviousLevel' 0 & repeat_start_instant 'rsi_CollapseFolders' 50ms & browser_window 'folders' & browser_scroll -1 & param_equal get_browsed_folder_tab 0 ? var_equal '$BRPreviousLevel' 0 ? browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing : browser_folder & set '$BRPreviousLevel' 0 & browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing : get_browsed_folder_tab & set '$BRPreviousLevel' & browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing : set '$BRPreviousLevel' 1 & repeat_start_instant 'rsi_CollapseFolders' 50ms & browser_window 'folders' & browser_scroll -1 & param_equal get_browsed_folder_tab 0 ? var_equal '$BRPreviousLevel' 0 ? browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing : browser_folder & set '$BRPreviousLevel' 0 & browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing : get_browsed_folder_tab & set '$BRPreviousLevel' & browser_scroll 'top' ? repeat_stop 'rsi_CollapseFolders' : nothing
Script added from PachN
Scripted by PhantomDeejay
Source: here
Button or key to change the browser view settings quickly to show just karaoke , or simple music files (for controllers or keyboard)
Show karaoke
view_options "showkaraoke" on & view_options "showmusic" off & view_options "showvideo" off
Show music
view_options "showmusic" on & view_options "showkaraoke" off & view_options "showvideo" off
Can be easily adapted for video
Script added from bigron1
Browse tracks with jogwheel/touchwheel when deck is empty
Touchwheel (Jog)
loaded ? touchwheel : browser_window 'songs' & var $shift ? touchwheel_touch ? param_multiply 100 & browser_scroll : param_multiply 50 & browser_scroll : touchwheel_touch ? param_bigger 0.02 ? param_multiply 8 & browser_scroll : param_smaller -0.02 ? param_multiply 8 & browser_scroll : param_bigger 0 ? browser_scroll +1 : browser_scroll -1 : cycle $b 5 & var_equal $b 4 ? param_bigger 0 ? browser_scroll +1 : browser_scroll -1 : nothingThis script enables you to browse your tracks with your jogwheel when there is no track loaded on the wheel's deck.
It does NOT change your wheel_mode, it will only (but also always) browse, when the deck is completely empty.
The idea with param_bigger 0 ? browser_scroll +1 : browser_scroll -1 is not from me, but i can't find the original post. However this is a much more improved version, as it makes the unusable state of the wheel with an empty deck useful with a lot of tweaking to create a good browsing performance.
It uses not only the shift variable to speed up - it also changes speeds depending on whether you have pressed your touchwheel or not.
If you want to use the shift 'feature', you need to have
set $shift 1 while_pressedsomewhere on your shift key.
To customize this script and learn about it's structure, click this link for the document (because it's too long for this post): vdjscript Document
Script added from unlimited
Auto-Deck-Load System [ADL]
You can put this script on any button.
It will automaticly load the next track in your playlist onto the other deck and delete it from the list when the currently running track has less than 30 seconds left.
It's a mix of automix and manual mixing, so you can make the transitions yourself but have the tracks loaded automaticly for you.
If you put this on a button where you can't individually control the LED (e.g. custom buttons), you should set up another LED (or custom button) with this script:
var $ADL ? on : offto know if the ADL-System is running or not, because the on-off script returns the wrong LED information!
set $ADL_left 0 & set $ADL_right 0 & var $ADL ? repeat_stop 'AutoDeckLoad' & set $ADL 0 : repeat_start_instant 'AutoDeckLoad' 500ms & set $ADL 1 & deck left select ? & deck left songpos_remain 30000ms ? var_equal $ADL_right 0 ? deck right playlist_load_and_remove & set $ADL_right 1 & set $ADL_left 0 & deck right select : nothing : nothing : deck right select ? deck right songpos_remain 30000ms ? var_equal $ADL_left 0 ? deck left playlist_load_and_remove & deck left select & set $ADL_right 0 & set $ADL_left
Load or Clone
(One Button per deck)
action_deck 1 ? param_equal '`deck 2 get_filepath`' '`get_browsed_filepath`' ? deck 2 clone_deck 1 : deck 1 load : param_equal '`deck 1 get_filepath`' '`get_browsed_filepath`' ? deck 1 clone_deck 2 : deck 1 load
(One Button for all decks, follows Master )
deck 1 masterdeck ? param_equal '`deck 1 get_filepath`' '`get_browsed_filepath`' ? deck 1 clone_deck 2 : deck 2 load : param_equal '`deck 2 get_filepath`' '`get_browsed_filepath`' ? deck 2 clone_deck 1 : deck 1 load
Skipping through browser windows back and forth
(for controller and keyboard)
For changing browser windows by using two buttons/keys (Right/Left). This makes it possible to change directions in any browser window:
Right:
browser_window 'folders' ? browser_window 'songs' : browser_window 'songs' ? browser_window 'sidelist' : browser_window 'sidelist' ? browser_window 'sideview' : browser_window 'folders'
Left:
browser_window 'folders' ? browser_window 'sidelist' : browser_window 'sideview' ? browser_window 'sideview' : browser_window 'sidelist' ? browser_window 'songs' : browser_window 'folders'
Script added from zehkah
djdad's autocolor script reworked
Assign the script below to a custom button. Select a folder. Press the custom button.
It will automatically color all the tracks inside that folder and will automatically stop at the last one. You can press the same button again to stop the process at any time.
repeat_start 'colorTracks' ? on & repeat_stop 'colorTracks' : off & browser_window "songs" & browser_scroll "top" & repeat_start 'colorTracks' 100ms & browser_scroll 'bottom' ? repeat_stop 'colorTracks' & get_browsed_song 'harmonic' & param_cast 'text' & param_equal '01A' ? browsed_song color '#70ECD4' : param_equal '01B' ? browsed_song color '#00EDC9' : param_equal '02A' ? browsed_song color '#92F0A4' : param_equal '02B' ? browsed_song color '#27EC82' : param_equal '03A' ? browsed_song color '#B1EE86' : param_equal '03B' ? browsed_song color '#85ED4E' : param_equal '04A' ? browsed_song color '#E6E0A2' : param_equal '04B' ? browsed_song color '#E0C86E' : param_equal '05A' ? browsed_song color '#FEC8AC' : param_equal '05B' ? browsed_song color '#FFA279' : param_equal '06A' ? browsed_song color '#FFB3BF' : param_equal '06B' ? browsed_song color '#FF8C93' : param_equal '07A' ? browsed_song color '#FFB4D2' : param_equal '07B' ? browsed_song color '#FF85B4' : param_equal '08A' ? browsed_song color '#EBB7F9' : param_equal '08B' ? browsed_song color '#F087D9' : param_equal '09A' ? browsed_song color '#E7B6F8' : param_equal '09B' ? browsed_song color '#CE93FF' : param_equal '10A' ? browsed_song color '#C0CEFB' : param_equal '10B' ? browsed_song color '#A1B9FF' : param_equal '11A' ? browsed_song color '#94E5F8' : param_equal '11B' ? browsed_song color '#3ED2F8' : param_equal '12A' ? browsed_song color '#50EBF0' : param_equal '12B' ? browsed_song color '#01EDED' : nothing : get_browsed_song 'harmonic' & param_cast 'text' & param_equal '01A' ? browsed_song color '#70ECD4' & browser_scroll +1 : param_equal '01B' ? browsed_song color '#00EDC9' & browser_scroll +1 : param_equal '02A' ? browsed_song color '#92F0A4' & browser_scroll +1 : param_equal '02B' ? browsed_song color '#27EC82' & browser_scroll +1 : param_equal '03A' ? browsed_song color '#B1EE86' & browser_scroll +1 : param_equal '03B' ? browsed_song color '#85ED4E' & browser_scroll +1 : param_equal '04A' ? browsed_song color '#E6E0A2' & browser_scroll +1 : param_equal '04B' ? browsed_song color '#E0C86E' & browser_scroll +1 : param_equal '05A' ? browsed_song color '#FEC8AC' & browser_scroll +1 : param_equal '05B' ? browsed_song color '#FFA279' & browser_scroll +1 : param_equal '06A' ? browsed_song color '#FFB3BF' & browser_scroll +1 : param_equal '06B' ? browsed_song color '#FF8C93' & browser_scroll +1 : param_equal '07A' ? browsed_song color '#FFB4D2' & browser_scroll +1 : param_equal '07B' ? browsed_song color '#FF85B4' & browser_scroll +1 : param_equal '08A' ? browsed_song color '#EBB7F9' & browser_scroll +1 : param_equal '08B' ? browsed_song color '#F087D9' & browser_scroll +1 : param_equal '09A' ? browsed_song color '#E7B6F8' & browser_scroll +1 : param_equal '09B' ? browsed_song color '#CE93FF' & browser_scroll +1 : param_equal '10A' ? browsed_song color '#C0CEFB' & browser_scroll +1 : param_equal '10B' ? browsed_song color '#A1B9FF' & browser_scroll +1 : param_equal '11A' ? browsed_song color '#94E5F8' & browser_scroll +1 : param_equal '11B' ? browsed_song color '#3ED2F8' & browser_scroll +1 : param_equal '12A' ? browsed_song color '#50EBF0' & browser_scroll +1 : param_equal '12B' ? browsed_song color '#01EDED' : browser_scroll +1
Script originally from djdad
Change crossfader curve between smooth and Scratch with single button or key
crossfader_curve smooth ? crossfader_curve Scratch : crossfader_curve smooth
This was requested by a user on the facebook page.
It checks to see if the current mode of crossfader_curve is smooth.
If true, it sets crossfader_curve to Scratch , otherwise it sets it to smooth.
Script added from a1kryten
Switch between pre and post fx (Custom Button)
setting "fxProcessing" "Post-fader" ? on & setting "fxProcessing" : off & setting "fxProcessing"
Drop gain & turn flanger On, Reset gain & turn flanger OFF (Button)
effect_active 'flanger' ? effect_active 'flanger' & get_var "resetGain" & param_cast & gain : set "resetGain" '`gain' & effect_active 'flanger' & gain -15%
This script keeps the output level at a similar level when using a FX that can increase the level.
This bit saves the current gain as a variable.
This bit gets the variable and uses it to set the gain.
Halve the pitch, double the pitch (Button)
toggle "1/2pitch" & var "1/2pitch" ? pitch & param_multiply 50% & pitch : pitch & param_multiply 200% & pitch
Combined dial with different scales, with correct centring dial
user wanted to have 1 dial control both eq_low & eq_mid at once but also wanted mid to be 1/2 as sensitive and also wanted the eqs centred when the dial was centred
deck 1 eq_low & deck 1 eq_mid & param_multiply 0.5 & param_add 0.25 & deck 1 eq_high
multiplies the calling slider by 0.5, but then to have eq high centred when the dial is centred add 0.25
maths for other scales to be centred
(constant 1 - scaling factor ) / 2 = correction
multiply by your scale, and add the correction.
Slipped Backspin with gain correction (Button)
set 'rsGainBS' '`gain' & gain -20% & slip on & effect_active 'backspin' & repeat_start_instant 'rsiBackSpin' 10ms & effect_active 'backspin' 1 ? nothing : repeat_stop 'rsiBackSpin' & play & slip off & get_var 'rsGainBS' & param_cast & gain
This script is a single button press, the current gain is saved, the gain is dropped, backspin FX is initiated, a repeat_start script continually checks the FX, when the FX is finished the gain is put back to normal and the track continues from the point where it would have been if the backspin never happened.
Load 5 effects on each deck (Button)
deck 1 level 75% & deck 1 effect_select 1 'EQ 10 Bands' & deck 1 effect_active 1 'EQ 10 Bands' on & deck 1 effect_button 'EQ 10 Bands' 1 & deck 1 effect_slider 'echo' 1 0 & deck 1 effect_select 5 'flanger' & deck 1 filter 0.5 & deck 1 effect_select 2 'Djos Special Flanger' & deck 1 effect_select 3 'Echo' & deck 1 effect_active 3 'Echo' on & deck 1 effect_select 4 'Loop Roll' & deck 1 effect_show_gui 1 on & deck 1 effect_show_gui 2 on & deck 1 effect_show_gui 3 on & deck 1 effect_show_gui 4 on & deck 1 effect_show_gui 5 on & deck 2 level 75% & deck 2 effect_select 1 'EQ 10 Bands' & deck 2 effect_active 1 'EQ 10 Bands' on & deck 2 effect_button 'EQ 10 Bands' 1 & deck 2 effect_slider 'echo' 1 0 & deck 2 effect_select 5 'flanger' & deck 2 filter 0.5 & deck 2 effect_select 2 'Djos Special Flanger' & deck 2 effect_select 3 'Echo' & deck 2 effect_active 3 'Echo' on & deck 2 effect_select 4 'Loop Roll' & deck 2 effect_show_gui 1 on & deck 2 effect_show_gui 2 on & deck 2 effect_show_gui 3 on & deck 2 effect_show_gui 4 on & deck 2 effect_show_gui 5 on & deck 3 level 0% & deck 4 level 0% &
Script added from DJDAD & JimmyL-DJ
LFO Filter (Button)
up ? repeat_stop 'wait' && filter 50% : filter 50% && repeat_start 'wait' 75ms & var 'up' ? filter +5% & filter 90% ? set 'up' 0 : set 'up' 1 : filter -5% & filter 10% ? set 'up' 1 : set 'up' 0 : set 'up' 1
Press and hold to get a LFO filter effect on a button
Change the "75ms" for faster/slower effect
Script added from klausmogensen
Noise effect as sweep (Button)
From Low:
effect_slider 'noise' 1 20% && effect_slider 'noise' 2 20% && effect_active 'noise' 1 && repeat_start 'wait' 300ms & effect_slider 'noise' 1 +1% & effect_slider 'noise' 2 +3% & effect_slider 'noise' 1 50% ? effect_active 'noise' 0 & repeat_stop 'wait'
From High:
effect_slider 'noise' 1 80% && effect_slider 'noise' 2 20% && effect_active 'noise' 1 && repeat_start 'wait' 300ms & effect_slider 'noise' 1 -1% & effect_slider 'noise' 2 +3% & effect_slider 'noise' 1 50% ? effect_active 'noise' 0 & repeat_stop 'wait'
Change the "300ms" for faster/slower effect and the effect_slider 1 and effect_slider 2 settings for different noise fx
Key change (dial)
param_add -0.5 & param_multiply 2 & key_move
param_add -0.5 & param_multiply 2 & key_smooth
Two scripts for key change on a dial,
"move" changes the key by multiples of 1 semitone [whole notes][-12, -3, +5 etc]
"smooth" changes the key by partial semitones [part notes[-11.06, -3.9, +5.2 etc]
Key Smooth (from -1 to +1) (dial)
param_multiply 0.16 & param_add 0.44 & key_smooth
Auto Half Loop (button)
Loop 1 & wait 2bt & Loop 0.5 & wait 1bt & Loop 0.25 & wait 1bt & Loop off
Loop 1 & wait 2bt & Loop 0.5 & wait 1bt & loop_move +4 & goto +4 & Loop 0.25 & wait 1bt & Loop off
updated with wait command
Control the Master volume of the sampler using a knob (for controllers)
sampler_volume_master
Note: You can control the volume using two button, or keys, one for up, the other for down.
Stop all the samples playing (for controllers or keyboard)
sampler_stop all
Use a button to play a specific named sample (for controllers)
Button
sampler_bank X & sampler_play_stop Y
Button LED
sampler_play Y on
where X= the bank number or name.
and Y=the sample number or name.
Note: If you're on a different sample page the normal slot volume control won't work, and hence you need to provide a Master sampler volume control. Two buttons (one up, the other down), or one knob will do the trick.
Toggle between the Master , and headphone sampler outputs (for controllers)
It also lights a LED when the headphone output is selected
Button
deck Master sampler_output ? sampler output "headphones" : deck Master sampler_output
Button LED
sampler output "headphones" on
Assign a button to mute the sampler output, and light its LED (for controllers)
Button
sampler_volume_master 100% ? sampler_volume_master 0% : sampler_volume_master 100%
Button LED
sampler_volume_master 0% on
FADE Script
I want to put this script here that locodog helped me for FADER use.
The Fade plugin from v7 no longer works on V8 and V8 does not have one, this is a script that you can assign to a button to do just that.
repeat_start_instant 'levelSweep' 10ms 101 & level & param_smaller 1% ? stop & level 100% & repeat_stop 'levelSweep' : level -1%
Here is a modified version of the script (if you getting a bump/hump/click noise etc..) use this change/modified version.
repeat_start_instant 'levelSweep' 10ms 101 & level & param_smaller 1% ? stop & repeat_stop 'levelSweep' & stop & repeat_start "WaitTimer" 100ms 1 & level 100% : level -1% : nothing
script added by The.Magic.DJ
Auto XF more like V7 (Button)
ONINT (add to the very end of your ONINT)
crossfader 0% & set "$XFside" 1 & repeat_start "rsXFcheck" 2000ms & crossfader 0% ? set "$XFside" 1 : crossfader 100% ? set "$XFside" 2 : nothing
Button
cycle "$AutoXF" 2 & var_equal "$AutoXF" 1 ? var_equal "$XFside" 1 ? deck Master repeat_start_instant "rsiXF" 10ms 101 & crossfader +1% & crossfader 100% ? deck Master repeat_stop "rsiXF" & set "$XFside" 2 & set "$AutoXF" 0 : nothing : var_equal "$XFside" 2 ? deck Master repeat_start_instant "rsiXF" 10ms 101 & crossfader -1% & crossfader 0% ? deck Master repeat_stop "rsiXF" & set "$XFside" 1 & set "$AutoXF" 0 : nothing : nothing : deck Master repeat_stop "rsiXF"
This script is a 2 parter, ONINT monitors the XF position every 2 seconds, if the XF was last @ 0% the button press will send the XF from left to right, if the XF was last @ 100% the button press will send the XF right to left.
Pressing the button during action will stop the action.
Set the LEFT and RIGHT video on DDJ-SZ per channel FX Selectors
with this script you can change the 1 and 2 buttons that are located on the top of each channel to act as a video selector.
This is useful when you have more than 2 videos playing, or want to HIDE the video without change the video level or change the volume levels.
to start, put this code in the ONINT (at the beginning): (optional)
deck 1 leftvideo & set '$lv' 1 & deck 2 rightvideo & set '$rv' 2 &
this will make the buttons light on and set the channels 1 and 2 as the default channels for left and right videos
Now, put the following code on the FX1_ASSIGN key into the mapper:
action_deck 1 ? var_equal '$lv' 1 ? on & leftvideo auto & set '$lv' 0 : off & deck 1 leftvideo & set '$lv' 1 : action_deck 2 ? var_equal '$lv' 2 ? on & leftvideo auto & set '$lv' 0 : off & deck 2 leftvideo & set '$lv' 2 : action_deck 3 ? var_equal '$lv' 3 ? on & leftvideo auto & set '$lv' 0 : off & deck 3 leftvideo & set '$lv' 3 : action_deck 4 ? var_equal '$lv' 4 ? on & leftvideo auto & set '$lv' 0 : off & deck 4 leftvideo & set '$lv' 4 : on & set '$lv' 0
This will make all the buttons marked with the number 1 as the LEFT VIDEO selectors. so if you wanna set the deck 3 as the LEFT VIDEO, you press the button on channel 3 marked with number 1 (at the top of the channel)
Now, put the following code on the FX2_ASSIGN Key into the mapper
action_deck 1 ? var_equal '$rv' 1 ? on & rightvideo auto & set '$rv' 0 : off & deck 1 rightvideo & set '$rv' 1 : action_deck 2 ? var_equal '$rv' 2 ? on & rightvideo auto & set '$rv' 0 : off & deck 2 rightvideo & set '$rv' 2 : action_deck 3 ? var_equal '$rv' 3 ? on & rightvideo auto & set '$rv' 0 : off & deck 3 rightvideo & set '$rv' 3 : action_deck 4 ? var_equal '$rv' 4 ? on & rightvideo auto & set '$rv' 0 : off & deck 4 rightvideo & set '$rv' 4 : on & set '$rv' 0
This will make all the buttons marked with the number 2 as the RIGHT VIDEO selectors. so if you wanna set the deck 1 as the RIGHT VIDEO, you press the button on channel 1 marked with number 2 (at the top of the channel)
Script added from Brunoliv
Switch between the default wave & Scratch wave (Button)
skin_panel "horizontal_scratch_active" ? skin_panel "defaultwave" : skin_panel "horizontal_scratch_active"
Zoom in or out of the wave (Button)
zoom "default" ? zoom 75% & zoom_scratch 75% : zoom "default" & zoom_scratch "default"
Zoom in or out with one button.
I use this with my Hercules MK4
Use the Shift Button (hold down) to add extra functions to buttons.
shift while_pressed
Change the Key with the Pitch Knob while Shift is pressed
PITCH
shift ? param_multiply 1 & key_move : param_multiply 0.25% & pitch
Move the Loop 1 beat +/- with with the TRACK buttons while Shift is pressed
shift ? loop_move -1 : seek -4
shift' ? loop_move +1 : seek +4
Only if you want:
Let the SOURCE button LED blink when SHIFT ist held down
LED_SOURCE
shift ? blink 500ms : off
Script added from megaalf
Navigation :
