Forum: Old versions
Topic: Full Screen Help Please!
Hello, I am stuck in full screen mode. I cannot see the anything on VDJ past the two virtual "turntables." There are also 2 black bars on the sides of my screen. How do I get out of this? I tried quitting the program and re-installing and it did not work. Please help me, thanks.
geposted Wed 26 Nov 08 @ 1:05 am
Hi ao312, Pls register ur serial at ur modify ur profile.
Abt ur issue, u can just minimize it;)
i have the same problem
no u cant minimize it BECAUSE U CANT SEE THE DAMN MINIMIZE BUTTON!
it's possible that your running an older version where the skin does not offer other types. I did notice crack version have this problem, but not to accuse anyone. I ran the crack version until I felt it was worth purchasing. I have to admit, it works well.
PLEASE HELP SOMEONE! This is the same thing that happened to me and i cant seem to make the program smaller
There is only one way to fix it...
...youll have to download the program from this site. The Torrent sites give beta versions.
Its funny how you stand out with the crack version of the program. LOL.
Download the trial version and you shouldn't have any problems. It's funny how desperate these guys sound :D
Change your native resolution to a larger size, or delete all but the default skins in documents/virtualdj/skins.
how do i acess the configuration panel manualy, like for example: (ctrl+alt+c) or what have you?? does antone have an clue, plz help. thnx.
click in the lil apple and click in system preferences, then in hardware click in displays
happy mixing
I had the exact same issue with mine, and it was NOT a result of having a stolen SN or anything (mine is registered.)
Sadly, I was stuck in a skin that didn't have any resize buttons. A keyboard shortcut for full-screen toggle sure would be handy. My only option was to delete the offending skin.
mp3jrick,
thanks man! you saved me.
My issue is with a Macbook Pro running OSX 10.7.3.
Mostly it works fine, but I cannot minimize VDJ at all. I have a minimize icon but it does nothing, I have also tried Command+m and it does nothing. So while VDJ is running, I can do nothing else. How do I rectify this problem?
(btw, this is the $99 version.....yes I paid)
Ok, don't flame the stupid nub. I guess I figured it out, I kept clicking the yellow minimize and trying command+m but it didn't work. Well have repeated attempts at fixing it, I finally clicked the green icon and it put VDJ in the background and at least let me get to the dock. whew! PC Boy goes mac.....pray for me!
I have run into the same problem while DJing live. Can't even see the minimize buttons. Tried everything and I've owned Mac products for 8 years. Had to play a CD off a CDJ and shut down the Macbook Pro and start all over again.
