Hello, I am stuck in full screen mode. I cannot see the anything on VDJ past the two virtual "turntables." There are also 2 black bars on the sides of my screen. How do I get out of this? I tried quitting the program and re-installing and it did not work. Please help me, thanks.
geposted Wed 26 Nov 08 @ 1:05 am
Hi ao312, Pls register ur serial at ur modify ur profile.
Abt ur issue, u can just minimize it;)
geposted Wed 26 Nov 08 @ 1:03 pm
i have the same problem
no u cant minimize it BECAUSE U CANT SEE THE DAMN MINIMIZE BUTTON!
geposted Sat 23 Jan 10 @ 6:11 am
it's possible that your running an older version where the skin does not offer other types. I did notice crack version have this problem, but not to accuse anyone. I ran the crack version until I felt it was worth purchasing. I have to admit, it works well.
geposted Sat 23 Jan 10 @ 10:16 am
PLEASE HELP SOMEONE! This is the same thing that happened to me and i cant seem to make the program smaller
geposted Sun 24 Jan 10 @ 11:03 am
There is only one way to fix it...
...youll have to download the program from this site. The Torrent sites give beta versions.
Its funny how you stand out with the crack version of the program. LOL.
geposted Mon 25 Jan 10 @ 5:42 pm
Download the trial version and you shouldn't have any problems. It's funny how desperate these guys sound :D
geposted Tue 26 Jan 10 @ 5:15 am
Change your native resolution to a larger size, or delete all but the default skins in documents/virtualdj/skins.
geposted Tue 26 Jan 10 @ 2:33 pm
how do i acess the configuration panel manualy, like for example: (ctrl+alt+c) or what have you?? does antone have an clue, plz help. thnx.
geposted Sun 14 Mar 10 @ 5:45 pm
click in the lil apple and click in system preferences, then in hardware click in displays
happy mixing
happy mixing
geposted Mon 15 Mar 10 @ 8:06 pm
I had the exact same issue with mine, and it was NOT a result of having a stolen SN or anything (mine is registered.)
Sadly, I was stuck in a skin that didn't have any resize buttons. A keyboard shortcut for full-screen toggle sure would be handy. My only option was to delete the offending skin.
geposted Thu 04 Nov 10 @ 4:18 pm
mp3jrick,
thanks man! you saved me.
geposted Sun 01 Jan 12 @ 2:26 pm
My issue is with a Macbook Pro running OSX 10.7.3.
Mostly it works fine, but I cannot minimize VDJ at all. I have a minimize icon but it does nothing, I have also tried Command+m and it does nothing. So while VDJ is running, I can do nothing else. How do I rectify this problem?
(btw, this is the $99 version.....yes I paid)
geposted Sat 05 May 12 @ 10:57 am
Ok, don't flame the stupid nub. I guess I figured it out, I kept clicking the yellow minimize and trying command+m but it didn't work. Well have repeated attempts at fixing it, I finally clicked the green icon and it put VDJ in the background and at least let me get to the dock. whew! PC Boy goes mac.....pray for me!
geposted Sat 05 May 12 @ 11:03 am
I have run into the same problem while DJing live. Can't even see the minimize buttons. Tried everything and I've owned Mac products for 8 years. Had to play a CD off a CDJ and shut down the Macbook Pro and start all over again.
geposted Mon 10 Sep 12 @ 8:56 am
