geposted Thu 19 Nov 09 @ 2:02 am
geposted Thu 19 Nov 09 @ 1:08 pm
It looks cool :-) yes I agree very handy to install in the floor and very close to the screen, very good.
geposted Thu 19 Nov 09 @ 7:18 pm
dJdAb - what size artists panels where you projecting on? and which exact pico projector are you using? It looks really cool.
geposted Sun 22 Nov 09 @ 7:09 am
new to cue, how to i project video from laptop to screen without everything on my laptop projecting also
geposted Sun 22 Nov 09 @ 5:44 pm
first off you need to have a dual core laptop... then hopefully this tutorial i made might help.
geposted Sun 22 Nov 09 @ 7:36 pm
This has been a valuable thread on projectors but Screens need to be taken into account as well.
Here is a screen size /throw calculator.
http://www.projectorcentral.com/projection-calculator-pro.cfm
You place the manufacturer and model of your projector in the calculator and it spits out the size of screen
Also takes into account, mounting position, ambient lighting, optimal seating distance
Very good things to know about if you need to custom build a screen & projector mount combo or just want to know how big your screen will be say at 5 feet throw.
Now before you go into a venue you can plan projector and screen placement.
geposted Wed 25 Nov 09 @ 9:49 am
just added to favourites, thanks.
geposted Wed 25 Nov 09 @ 11:14 am
TDBennett wrote :
http://www.aaxatech.com/products/p2_pico_projector.htm
Sharp SVGA (800x600) resolution
Bright 33 Lumen LED light source
1GB onboard memory + microSD reader
MP4, MP3, AVI, JPG, WMV decoder
Projects up to a 80" image*
*(In low-light conditions)
VGA, RGB, iPod, PSP, PDA, DVD input
33 lumens seems low but the demos on the site show that it gives a good image and DJDab's images look good.
No keystone correction and the limited resolution could cause issues. Great option for the right applications and the price is right.
I like my NEC VT540, it's old but you can't beat a 15' diag. image on the side of a garage that the whole neighborhood can enjoy.
Thanks for sharing DJDab.
Does anyone have the P2 Pico Projector in use now, I'd like to know if it's a good buy for small club gig's.
Thanks
Joey...
geposted Sat 05 Dec 09 @ 9:31 pm
@dj dAB: your setup is AMAZING. could you please post more technical details (computer, case, screen size, projected image size etc.)...
geposted Tue 08 Dec 09 @ 4:19 am
I'm currently looking at one of these as the Aaxa Pico P2 is not available in the UK yet;
http://www.personalprojector.co.uk/catalog/product_info.php/products_id/29#Adapt305
Anybody use one of these?
Any comments before I splash the cash?
geposted Sun 13 Dec 09 @ 11:42 am
Hey DJSoulman
That's a P2 repackaged;
well what I can tell you is that it's very nice, but if you're looking to use it for clubs and party venues then it's not bright enough to handle that type of job, other then that it's good.
I'm sending mine back for a larger unit HS102 http://www.aaxatech.com/products/hs102_micro_projector.htm
Good Luck
Joey.....
Good Luck
Joey.....
geposted Sun 13 Dec 09 @ 12:20 pm
What I had in mind is not a full screen onstage but more a display behind me in the DJ booth. Like a LCD size screen display 40-50 inches.
That way keeps it simple and portable without having to mount somewhere remote with long wire runs etc.
Good enough for this?
geposted Sun 13 Dec 09 @ 3:15 pm
That er work, but the ambient lighti needs to be very low.
Let me know how it all worked out.
Joey....
geposted Sun 13 Dec 09 @ 4:03 pm
A good Projector is the Optoma EP 1691 720p HDMI input
geposted Sun 13 Dec 09 @ 6:06 pm
I use one of these:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4199520&CatId=1759
500:1 lens - Makes a 62 inch image at only a 4 foot throw. Bright as hell in a fully lit room at that distance.
geposted Sun 13 Dec 09 @ 7:25 pm
Both of the above suggestions are fine but a lot more expensive.
geposted Sun 13 Dec 09 @ 7:40 pm
The cheaper ones will leave you disappointed. Think of it as buying a behringer mixer or Denon mixer
geposted Sun 13 Dec 09 @ 10:49 pm
Hi DJ Marcel_1
You're right that unit is excellent, but I have some questions.
1. How often do you use the unit.
2. What length of time is the unit on per use.
3. How often do you change the Bulb.
4. How expensive are the replacement bulbs.
Thank You
Joey....
Thank You
Joey....
geposted Mon 14 Dec 09 @ 10:35 am
Thank You
Joey....
Thank You
Joey....
1) Once a week - Saturday Nights for Mobile DJ'ing. (Weddings, company gala's)
2) 6 - 10 hours per use.
3) Haven't replaced the bulb yet
4) Special order from Benq (approx 400.00 CAD)
geposted Mon 14 Dec 09 @ 9:42 pm
