Ho apportato alcune modifiche ai mapper di default di Virtual DJ 7 per i controller Hercules HDJC(MK1) - MK2 - MP3 - MP3 e2 - MK4 - 4-Mx - RMX - Steel.
v1.7
- Ability to change the parameter 1 and 2 of effect active, when an audio effect is active the rotation of the left Jog change the parameter 1 and right Jog change the parameter 2 (similar to Pioneer CDJs), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch.
Old mapper action was "effect active ? param_multiply 300% & effect slider 1 : jog_wheel", if you don't like new 2 Jogs way to control effect you can past the old one in VDJ mapper page.
In the Hercules 4-Mx when an audio effect is active the rotation of the Jog change the parameter 1 and the Ctrl knob change the parameter 2 (similar to Pioneer CDJs), when effect turn back off to the Jog function coming back to Pitch Bend / Scratch and the Ctrl knob change the Filter.
To reset the filter push Shift.
In the Hercules Steel the effects parameter 1 and 2 can be changed with the two top left knobs, when the "Applt Ctrl. On" Led it's ON it indicate if knobs works for Deck A or B, in Select mode the two knobs it apply the filter of DecK A and B.
- Ability to scroll fast within the track with Jog, just press the |< or >| button and rotate the Jog.
- Pitch bend make short seek when track is in pause
- Ability to make "browsing" of the tracks with jogs, simply hold the "Cue Select" button on the deck and rotate the Jog. (No Hercules MK2)
Note: that only works on one deck/jog at one time.
- Hold on the load button for more than half a second to unload the track from the deck.
- Fx and Loop leds blink when Fx or Loop are activated into Hercules MP3, MK2 and HDJC(MK1).
- Added blink on Play/Pause buttons when the song is paused (No Hercules Steel because it have the Stop led).
- Advance configuration of the 6 + 6 (shift mode) buttons in 4-Mx, RMX and Steel to scroll and use FX, Loop and 6 Hot Cues.
In the RMX the Source button is used like a shift, Hold on it for more than half a second to enable/disable Timecode_bypass.
Note: Loop under 1/8 or bigger then 32 don't work with actions loop_half & double, if you don't want this limitation change "loop_half" to "loop_length 50%" and "loop_double" to "loop_length 200%".
Here the mapper button to button:
BUTTON1 -> loop_button
BUTTON2 -> effect active
BUTTON3 -> effect select +1
BUTTON4 -> loop_double
BUTTON5 -> loop
BUTTON6 -> loop_half
BUTTON7 -> holding ? delete_cue 1 : hot_cue 1
BUTTON8 -> holding ? delete_cue 2 : hot_cue 2
BUTTON9 -> holding ? delete_cue 3 : hot_cue 3
BUTTON10 -> holding ? delete_cue 4 : hot_cue 4
BUTTON11 -> holding ? delete_cue 5 : hot_cue 5
BUTTON12 -> holding ? delete_cue 6 : hot_cue 6
- Advance configuration of the 4 + 4 (shift mode) buttons in MK4 and MP3 e2 to scroll and use FX, Loop and sample 1.
BUTTON1 -> loop_half
BUTTON2 -> loop_double
BUTTON3 -> loop
BUTTON4 -> sampler play_stop
BUTTON5 -> effect select -1
BUTTON6 -> effect select +1
BUTTON7 -> effect active
BUTTON8 -> sampler rec
Dovete unzippare il file XML del mapper che vi interessa e copiarlo/sovrascriverlo nel percorso
Documenti\VirtualDJ\Mappers (fatelo con Virtual DJ chiuso)
e vi ricordo inoltre che per ripristinare il mapper originale vi basta cliccare sul tasto indicato sotto.
Download: http://it.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
geposted Thu 03 Jun 10 @ 3:19 am
