Forum: VirtualDJ Plugins
Topic: Noise Effect (like the Pioneer DJM-2000) - Page: 2
@ Jame: If you try older skins, like MixStation, there was such a feature to mix high-mid-low frequencies through dedicated crossfaders.
It is not possible to do with single plugins, or with master channel effects in VirtualDJ. There's a way to do that, but it's rather tricky for both the plugin developer and the final user, since the latter has to enable the effect on both decks.
Ah, I see try these:
eq_crossfader_high
eq_crossfader_mid
eq_crossfader_low
This will cross from "deck left" to "deck right" and vice versa. So on a true 4 deck skin you will have to toggle decks to the crossfader. Its a bit friendlier on a L-R Logic skin, IMO.
Those actions were designed for a 2-decks use, and I think that people stopped using them... the only skin I used with those feature was the aforementioned MixStation, back in the VDJ 3.4 & 4.x era...
Eq-crossfaders are still usable for multi deck skins. They behave like the crossfsader. They follow the crossfader channel assignment. And there are quite enough ver 6, ver 7 skins with these actions.
Need the noisebell and gates effect ported to mac. essential!
I loved it. Thanks for this.
@Hero where did you find it cause I can't find the link. Can you post it??
Thanks buddy
Huey
Hi all, this effect is so amazing.. My friend (Pro DJ) got it from here and im really impressioned.. But unlucky i'm only 16 years old and i can't afford to be a member of Virtual DJ site, but i would very love that! When i saw this effect on a DJM - 2000 i felt in love with it. I don't ask for nothing more, i just want to get chance to get that effect and succes in my Dj-ing. Sorry if this is not a good place to post this, but Dj-ing is my hobby that will never be backwarded.. Thanks for reading. Sincerely Dj Mirkoni.
Protection error 8
what that mean?
You have to contact support for protection errors. Please don't bump topics on different subject.
find where to download for vdj 7, noise effect ? please give me a site where to download this effect and how to put it in vdj
Sorry, skins, effects, samples and other add-ons are only available to registered licensed users of VirtualDJ who have purchased the software.
To be able to download, you will need to purchase VirtualDJ or register your serial number: http://www.virtualdj.com/products/comparison.html
If you have already purchased, please register your serial number on your profile page to gain access to plugin downloads: http://www.virtualdj.com/users/edit.html
Once registered, you can download from our plugins page. For example, here are some 'noise' effects: http://www.virtualdj.com/addons/effects.html?category=audio&order=default&platform=all&search=noise
NOTE: Links to 3rd party sites are not permitted and no users here will provide you with links to sites to illegally download VirtualDJ add-ons. If you like VirtualDJ, please support the software and its future development by purchasing it.
