Hello together!
The Pioneer DJM-2000 has got an effect that generates a noise sound like an "uplifter" in electronic music.
There are so much plugins for Virtual Dj (and Virtual Vinyl).
But no plugin like a noise generator...
Could someone create a plugin like this?
Maybe with a slider for the frequency, the volume, or a setting to automatically lift up the noise by a number of beats.
And of curse a slider to performe manually.
And it would be very good if the effect is not bound on a playing deck...
So that it could be used as an independent effect without playing music in the background.
Hope someone could make it real...
Thank you!! ;)
Andy Chiles
Virtual Vinyl 6.1.2
Thank you!! ;)
Andy Chiles
Virtual Vinyl 6.1.2
geposted Mon 11 Oct 10 @ 3:33 am
Do you mean this one?
That's already partially done with my Gates effect, so I can publish a derived FX with only that filtered white noise ;-)
geposted Mon 11 Oct 10 @ 8:21 am
Hey!!
Yes I mean this one!
I hoped that you would read it, because I work with your effects only!
That's truly no joke... I think your plugins are the best!
I'm an a little bit more famous dj in Germany and GB...
I mean I worked on dropping my name in the world wide scene...
(But everyone is kidding about me, because I'm playing with virtual dj) xD
So if you could publish a plugin like this you would make me a big favor!!
Maybe we could work together...
Like maybe I could help you to make the plugin more efficient or refine it...
How long would you need to program a effect like this??
geposted Mon 11 Oct 10 @ 2:37 pm
On the same basis a plugin like the way the equaliser mixing on the pioneer would also be awesome
geposted Mon 11 Oct 10 @ 3:04 pm
Each time I release a new or updated plugin, I always refine my "C++ FX library". As for now, it might take only a few days on&off (after university), since I already have the basic modules to implement such a plugin.
As far as I can see form the DJM-2000 video, the main requirements may be:
_ a slider to change the band-pass filter center frequency
_ a slider to change the band-pass filter bell width
_ an optional sweeping LFO frequency slider, with enable button and quantization switch
I think this would be enough. As written before, if you want to execute gating just use the Gates effect.
I don't get that. Do you mean the EQ effect on the DJM-800? That would be damn tricky to implement, since it involves two decks and not just one...
geposted Mon 11 Oct 10 @ 3:55 pm
*-*THK y
geposted Tue 12 Oct 10 @ 6:45 am
On the DJM-2000 its only one potentiometer...
But on the DJM-2000 you cant set the frequency of the noise...
So this would be a good piont to increase...
But what I would please you for is:
KEEP IT SIMPLE! Please!
So its just one slider that filters a noise effect from a Low-Pass filter to a Hi-Pass Filter...
The other things should be useful addition, but there are some effetcs where the one thing doesn't work with another setting
that you have to do first... And there always must be a playing deck... Thats very bad...
So if you could get this things to work it would be awesome!!!
Thank you!
Thank you!
geposted Tue 12 Oct 10 @ 7:56 am
where can we find this GATES?
geposted Wed 10 Nov 10 @ 5:50 pm
UPDATE
As requested, I've made a new plugin called NoiseBell to have such a noise effect. It is not only similar to that of DJM-2000, but it is also better, since you can add echo and can go from a harsh noise to a sweet narrow-band sound.
NoiseBell:
http://www.virtualdj.com/addons/12202/NoiseBell.html
Gates: (will be updated soon, since the noise volume seems not to work properly)
http://www.virtualdj.com/addons/11858/Gates.html
NoiseBell:
geposted Thu 11 Nov 10 @ 1:27 am
Can Someone port the Gates and the NoiseBell to Mac? I hope someone is working on that! Is It Cyder who usually port these things to the Mac side?
geposted Thu 11 Nov 10 @ 8:21 am
No Cyder has nothing to do with that.
Converting plugins for Mac is at the charge of its author but I can sometimes help.
geposted Sat 13 Nov 10 @ 5:01 pm
If someone will create this effect write here :) becouse i really need and like this effect.
geposted Sun 14 Nov 10 @ 2:27 pm
As you can read above the effect already exists, but you can't have it because you don't own a valid licence. If you want it, buy the program so that you can support developers, in order to make better products.
geposted Sun 14 Nov 10 @ 5:12 pm
Thank you DJcel, I meant you. Thank you.
geposted Mon 15 Nov 10 @ 12:48 am
The crush(er) effect was mentioned around about 5:15 into the video is that effect already possible with vdj or could it be implemented please.
Apologies, just checked plugin section already available... thanks.
geposted Mon 15 Nov 10 @ 5:58 am
Do you mean NoiseBell ?
geposted Mon 15 Nov 10 @ 6:00 am
Yup! :-)
geposted Mon 15 Nov 10 @ 8:37 am
as always nice effect by Texzk!
thanks for this :)
thanks for this :)
geposted Mon 15 Nov 10 @ 8:39 am
I think what DJJamesLake was talking about is similar to what's on my Pioneer DJM-909, most of the effects can be isolated to/from high, mids or lows specifically or in combination on 1 channel. Does that even make sense? I can choose to have the effect affect each band (high, mid, low) separately or in combination. I hope that makes sense...
In any case, thanks for the plug-in Tex!! Cant wait to try it out!!
geposted Mon 15 Nov 10 @ 7:08 pm
Not quite this is what I meant
http://www.youtube.com/watch?v=9u2cj_WmUyM
geposted Mon 15 Nov 10 @ 9:11 pm
