Topic: Can i/we convert mp3/wav to vdj?
Can we convert mp3 to vdj ? Because its too hard to one by one of the samples. THANKS
geposted Sun 17 Apr 11 @ 11:18 am
you can just rename them, no convertion is needed.
Really ? THANKS lemme try.
It doesn't work help please :(
I also have confirmed that this does not seem to work. Changing the file extension does not make a difference.
I think he is saying you can rename the .vdj to .mp3, not the other way around. And the sampler will use .mp3 with no issues.
yea it can be done in sample where u select your effect and then save it save as .vdj
