Can we convert mp3 to vdj ? Because its too hard to one by one of the samples. THANKS
geposted Sun 17 Apr 11 @ 11:18 am
you can just rename them, no convertion is needed.
geposted Sun 17 Apr 11 @ 12:05 pm
Really ? THANKS lemme try.
geposted Sun 17 Apr 11 @ 12:26 pm
It doesn't work help please :(
geposted Sun 17 Apr 11 @ 11:04 pm
I also have confirmed that this does not seem to work. Changing the file extension does not make a difference.
geposted Mon 18 Apr 11 @ 12:00 am
I think he is saying you can rename the .vdj to .mp3, not the other way around. And the sampler will use .mp3 with no issues.
geposted Mon 18 Apr 11 @ 1:00 am
yea it can be done in sample where u select your effect and then save it save as .vdj
geposted Sat 07 Oct 17 @ 2:50 pm
