Topic: Reverse play when right clicking PLAY button.
Greetings,
In version 7 I right click my PLAY button and get REVERSE. It works great for rocking videos back and forth.
Version 8 has a different function for right click on the PLAY button.
Do I need to get into my version 8's skin XML file to make the change? Or is there something in the SETINGS.XML I can modify for this change?
geposted Tue 19 May 15 @ 6:52 am
It's in the skin.
Thanks,
This is in my Version 7 skin XML. But I haven't found it in my Version 8 XML. I'm using FRUIT's skin. Searching.
Play_Stutter
<button pannel="deck1a" action="deck 1 play_button" rightclick=" deck 1 reverse while_pressed">
<pos x="230" y="223"></pos>
<size width="39" height="23"></size>
<selected x="378" y="380+900+256"></selected>
<over x="378" y="380+1400+256"></over>
<down x="377" y="380+899+256"></down>
</button>
UPDATE: Errrr.... can't find it. The XML formats are completely different. Can't even find KEY to change the font size and selection order. Not having much luck. Tired going to bed.
Made this change. Zipping now to see if it works.
*** Transport ***
<button action="play_options">
<tooltip>PLAY OPTIONS</tooltip>
<size width="18" height="18"/>
<pos x="1220+319+63+63+63+63+54" y="319"/>
<up x="1584" y="1729"/>
<over x="1584" y="1729"/>
</button>
<button action="play_button" rightclick="deck1 reverse while_pressed">
<tooltip>PLAY</tooltip>
<size width="60" height="27"/>
<pos x="1220+319+63+63" y="319"/>
<down x="1731" y="1752"/>
<over x="1731" y="1724"/>
<up x="486" y="1227"/>
<icon sysicon="play_button" width="25" height="25"/>
</button>
UPDATE: Didn't work. I confirmed this modification wss in the 4Deck.xml.
Can anyone confirm if I have the script correct? VDJ 8's XML is different than Version 7.
I'd love to get my PLAY buttons on the 4 decks to allow me to rock videos back and forth like I had it in Version 7.
Help please.
Jimmy
Skip the deck part or it will always act on deck 1 regardless of which deck you press it on
<button action="play_button" rightclick="reverse while_pressed">
Ok thanks I'll try it. Only thing is it doesn't reverse on DECK 1 with this change to the skin's XML.
That did it. Now off to get the other 3 decks.
Thank you. Thank you. Thank you.
Jimmy
