Greetings,
In version 7 I right click my PLAY button and get REVERSE. It works great for rocking videos back and forth.
Version 8 has a different function for right click on the PLAY button.
Do I need to get into my version 8's skin XML file to make the change? Or is there something in the SETINGS.XML I can modify for this change?
geposted Tue 19 May 15 @ 6:52 am
It's in the skin.
geposted Tue 19 May 15 @ 6:55 am
Thanks,
This is in my Version 7 skin XML. But I haven't found it in my Version 8 XML. I'm using FRUIT's skin. Searching.
Play_Stutter
<button pannel="deck1a" action="deck 1 play_button" rightclick=" deck 1 reverse while_pressed">
<pos x="230" y="223"></pos>
<size width="39" height="23"></size>
<selected x="378" y="380+900+256"></selected>
<over x="378" y="380+1400+256"></over>
<down x="377" y="380+899+256"></down>
</button>
UPDATE: Errrr.... can't find it. The XML formats are completely different. Can't even find KEY to change the font size and selection order. Not having much luck. Tired going to bed.
Play_Stutter
</button>
geposted Tue 19 May 15 @ 7:13 am
Made this change. Zipping now to see if it works.
*** Transport ***
<button action="play_options">
<tooltip>PLAY OPTIONS</tooltip>
<size width="18" height="18"/>
<pos x="1220+319+63+63+63+63+54" y="319"/>
<up x="1584" y="1729"/>
<over x="1584" y="1729"/>
</button>
<button action="play_button" rightclick="deck1 reverse while_pressed">
<tooltip>PLAY</tooltip>
<size width="60" height="27"/>
<pos x="1220+319+63+63" y="319"/>
<down x="1731" y="1752"/>
<over x="1731" y="1724"/>
<up x="486" y="1227"/>
<icon sysicon="play_button" width="25" height="25"/>
</button>
UPDATE: Didn't work. I confirmed this modification wss in the 4Deck.xml.
Can anyone confirm if I have the script correct? VDJ 8's XML is different than Version 7.
I'd love to get my PLAY buttons on the 4 decks to allow me to rock videos back and forth like I had it in Version 7.
Help please.
Jimmy
*** Transport ***
</button>
</button>
Help please.
Jimmy
geposted Thu 21 May 15 @ 3:21 am
Skip the deck part or it will always act on deck 1 regardless of which deck you press it on
<button action="play_button" rightclick="reverse while_pressed">
geposted Thu 21 May 15 @ 3:42 am
Ok thanks I'll try it. Only thing is it doesn't reverse on DECK 1 with this change to the skin's XML.
geposted Thu 21 May 15 @ 3:50 am
That did it. Now off to get the other 3 decks.
Thank you. Thank you. Thank you.
Jimmy
Jimmy
geposted Thu 21 May 15 @ 3:55 am
