I have two MC6000 Mk1 and both behave the same.
Sometimes when playing a song the play button does not light, and sometimes both cue and play lights at the same time.
Is there a bug inside the MC6000 firmware or in VDJ8? Have anyone else noted this?
It's just the leds, and the buttons work as they should so a minor bug...
geposted Mon 07 Sep 15 @ 6:03 pm
Took a look at the mapping files and everything seems OK. So i guess a firmware bug indeed. Did you check for an update ?
There is also a chance that due to a high speed of data (version 8 sends Midi Out with almost double speed) the Leds of the MC6000 "miss" the action to turn/off and therefore not getting updated. We have seen this behavior with some old units (in LCD displays mainly).
Just a try.. goto Settings-->Options (enable Advanced Options) and set the ControllerRefreshrate to e.g. 40 or 50 and see if you get the same issue.
geposted Mon 07 Sep 15 @ 6:23 pm
Also what OS are you using ?
If you're using Windows Vista it's common for that OS to have it's MIDI buffer fill more easily and truncate MIDI messages resulting various issues with all kind of MIDI devices. We strongly recommend to use Windows 7 or above...
geposted Mon 07 Sep 15 @ 6:45 pm
Dual staff experts reply - highly appreciated!
I'm running Win7 Pro, have not the guts to run anything else when most of it works so flawless as it is now.
Will try the controller refresh rate settings, thanx! (Current setting of refresh rate is 0 = 10mS)
BTW - Is it only the leds, displays and such stuff that is affected by this setting? And not midi commands sent from the controller?
geposted Mon 07 Sep 15 @ 7:21 pm
Yes, it's how fast the computer will try to update the leds of the controller. The commands from the controller to computer are always executed immediately
geposted Mon 07 Sep 15 @ 7:37 pm
Wich version of driver ASIO using ?
geposted Tue 08 Sep 15 @ 9:57 am
I'm using Asio 1.01 "for controllers"
geposted Tue 08 Sep 15 @ 10:57 am
The "Denon_DJ_MC6000_Driver_v1.0.1 (2015)" it's bugged.
I'm tried it with Windows 8.1 and with Windows 10, but it always had a bad response on led of controller.
I'm back to "Denon Setup ASIO Driver 222" and it's work better than 1.0.1 (2015) in Windows 8.1 and Windows 10.
This issue are reported also in VDJ German forum (http://it.virtualdj.com/forums/132945/German_Forum/Denon_DN-MC6000_(Stammtisch).html )
geposted Tue 08 Sep 15 @ 11:07 am
With MC6000MK1 you should NOT use the "for controllers" ASIO driver.
The "for controllers" is for the newer generation of DENON controllers such as MC6000MK2
geposted Tue 08 Sep 15 @ 11:16 am
The "Denon_DJ_MC6000_Driver_v1.0.1(2015)" ASIO driver are not the "for controller" version (such as for MK2), but it's present as supported ASIO driver, in offcial DN-MC6000 MK1 home page.... but it's buggy.
http://denondj.com/products/view/dn-mc6000#.Ve7LcXnou70
geposted Tue 08 Sep 15 @ 11:52 am
Strange! Seems weird to downgrade the asio driver to an older one. But if you say 2.22 is the one to go I will try it.
geposted Tue 08 Sep 15 @ 12:37 pm
MrJackson2014, if you go in VDJ German (http://it.virtualdj.com/forums/132945/German_Forum/Denon_DN-MC6000_(Stammtisch).html) and read lastest post you can see it's a wider problem (there are also photos of DN-MC6000 led problem). You can use Google translator to understand.
I'm had used 2.22 version on Windows 8.1 for 6 months and now, from a week ago, on Windows 10 without issue.
geposted Tue 08 Sep 15 @ 1:20 pm
Why are people still using the terrible Denon Asio drivers when WDM works trouble free?
geposted Tue 08 Sep 15 @ 1:50 pm
For me, 2 reasons:
1) I had used for 3 years ASIO driver, with VDJ 7 and no issue
2) When I upgrade to VDJ 8, ASIO 2.22 still work and I had no reason to change it
I also read in some forums that WDM are better, expecially with Denon DN-MC6000, but when I was tried to configure it on Windows 8.1 I had no success to work... so I stayed with ASIO driver.
Now I new installation of Windows 10 on my notebook: I'll try to reconfigure with WDM and I hope it can work.
geposted Tue 08 Sep 15 @ 2:06 pm
WDM works fine on both my Windows 8.1 machines.
geposted Tue 08 Sep 15 @ 2:35 pm
I haven't had any issues called "terrible" with the asio still. What problem are the asio driver causing?
geposted Tue 08 Sep 15 @ 3:25 pm
They cause glitches and when the music is quiet you can hear crackling. Normally setting a higher latency solves it but that's not the case all the time with these drivers.
geposted Tue 08 Sep 15 @ 3:36 pm
I apologize, I mixed the different ASIO versions.
I'm using the MC6000 Mk1 Driver 1.01 (2015) and not the "for controller" version.
A thought, the ASIO driver is only taking care of the audio streaming and not the midi data sent to and from controller buttons and leds?
Kradcliffe: Does the problem with crackling audio exsist even in 2015 version of ASIO or perhaps older versions?
geposted Tue 08 Sep 15 @ 6:46 pm
As reply above, the "MC6000 Mk1 Driver 1.01 (2015) " not work correctly with controller LED, tested by me with Windows 8.1 and on new setup of Windows 10 and reported by other users in VDJ German Forum.
With ASIO driver 2.22 I used it on every my gigs (every week-end) without any issue.
Now, as suggested by kradcliffe, I configure VDJ 8 with WASAPI driver and testing it.
geposted Tue 08 Sep 15 @ 8:13 pm
I also have massive Problems with Denon asio Drivers in VDJ8. (from crackling in Version 2.2.2 up to Dropouts in 1.0.1 2015)
The Problems were on Windows 7 and Windows 10
After uninstall the damn Denon asio Driver, my System works excellent with WASAPI and Windows 10!
geposted Wed 09 Sep 15 @ 5:23 am
