It's strange why some people is getting bad performance from the Denon ASIO drivers.
I wonder if it might be a combination of other drivers installed on the same machine.
I have two very clean installs of ASIO 2.22 tested through MC6000 and HC4500 and no crackling or other bad performance what so ever.
The only thing was that leds was not updated correctly. But that seems to be fixed by changing controller refresh parameter in options.
geposted Wed 09 Sep 15 @ 10:19 am
No-one is sure why this happens. I have had the problem on various "clean" machines all with good latency readings.
I found there was no point persevering when WDM works great and you don't even need to install anything for it to work.
geposted Wed 09 Sep 15 @ 11:16 am
