Hello i recently bought a new macbook and am wondering how to build a setup that plays 1 channel thru speakers and 2nd on my headphones? All I could managed to do was that it plays one through my left headphone and another one through my right. If some1 with the same computer or knowledge would help me clear this problem.
Regards,
Jan
Regards,
Jan
geposted Sun 14 Jan 18 @ 1:20 pm
Please read the information provided in the VDJ wiki...
https://www.virtualdj.com/wiki/Pre-listening.html
geposted Sun 14 Jan 18 @ 3:00 pm
Thank you for that, so if i’m correct I cannot do this with only laptop i will need a controler or mixer at least?
geposted Sun 14 Jan 18 @ 9:36 pm
From the wiki...
"you will either need two sound cards, a sound card with multiple outputs, or a controller with a built-in sound card"
geposted Sun 14 Jan 18 @ 9:55 pm
As a quick fix, get a cheap USB soundcard from Amazon or eBay. I got one for less than 5 pounds. It works just fine at home, but I would not trust it at a gig.
You can then set it up as in the Wikki (Option B).
geposted Sun 14 Jan 18 @ 10:20 pm
