i have mapped: sampler_position 1 and param_invert & param_cast ‘percentage’
but can i convert this % in time remain about sample 1??
geposted Sun 31 Oct 21 @ 12:41 pm
not really,
what about loop samples ? pitched samples ?
but with some hack retrieving needed info from various places :
browser_window sampler & browser_scroll top & browser_scroll 2 & browser_scroll -1 & param_multiply 'get_browsed_song length ms' 'sampler_position 2 & param_invert & param_mod 1' & param_cast
will return remain of playing sample in slot #2 or 0 if not playing
(took #2 in a way to see the 2 places where slot is needed
for slot #1 only a shorter script can apply - top being slot #1
browser_window sampler & browser_scroll top & param_multiply 'get_browsed_song length ms' 'sampler_position 1 & param_invert & param_mod 1' & param_cast & debug & get_browsed_song bpm & param_cast & debug & get_bpm & param_cast & debug
would need to take care about bpm too with pitched samples, but don't know how to get this info
geposted Sun 31 Oct 21 @ 6:21 pm
trying to set color dynamically using 3 variables myred mygreen myblue (affected to a slider)
debug script:
set zero `get_text '0.0'` & set mycompositecolor 0 & param_add "get_text ' `get_var myred & param_equal 0 ? get_var zero` `get_var mygreen & param_equal 0 ? get_var zero` `get_var myblue & param_equal 0 ? get_var zero``' " "get_text '`color' " & param_cast text & debug & debug text & set mycompositecolor & param_cast & debug & debug set & & param_cast & get_text `get_var mycompositecolor` & param_cast text & color & debug & debug color
what is strange :
this is working correctly once only, and every time the script is modified
all other calls restore the first set of value ( does not apply variables anymore but reset color to initial one)
what is more strange:
set multiple buttons all will work but all buttons will have their own first value set as default, every button setting their own default color
in every case working or not, there is something to investigate with these working mode
debug script:
what is strange :
geposted Mon 01 Nov 21 @ 6:05 am
'set' caches the action it uses, it is not really expecting an external parameter as action that is changing
geposted Mon 01 Nov 21 @ 7:00 am
OK, can get very strange things with that ;) , specially some int ==> HEX and color ==> int
for now the old " custom_button_name " hack can workaround the set being one shot
so that color can be set to things like that " get_text `custom_button_name 3 & param_cast text 9` & color "
geposted Mon 01 Nov 21 @ 12:44 pm
Some time ago now, I requested that the sampler have assignable trigger modes to either individual pads or pages, rather than being a global setting - so that (for example) a page of video clips can be in on/off mode, but a page of cowbell samples can be in stutter mode.
Having to change mode manually when switching between different types of bank is tedious.
As it's not been implemented, I was wondering if such a thing could be scripted?
So the script would check to see which bank is loaded and change the trigger mode to suit.
geposted Mon 01 Nov 21 @ 6:33 pm
I do not see any elegant way
problem is bank --> mode association
if for example it is a tag in first sample (user field or alike) detection can be done using browsed_song and mode set using sample_mode
would needs a rsi lookin for bank change or custom skin with dedicated "is_using" sampler script for instance in some multibutton
badly this solution changes browser window and focus to sampler first sample
maybe assigning a color to a mode could be a solution ?
geposted Mon 01 Nov 21 @ 7:13 pm
hi! i have malped a button: get_browsed_folder & param_equal ‘Recordings’ ? browser_window ‘songs’ & browsed_title ‘Sequencer8’ ? get_text ‘full’ : get_text ‘Ready’
but with this script i have text ‘full’ only if i have in browser_window ‘songs’ focus on ‘Sequencer8’ track, i would that check in Folder ‘Recordings’ there is a ‘Sequencer8’ track or sample, and if there is…..get_text ‘full’, indipendently where is focus….can you help me?
geposted Wed 03 Nov 21 @ 7:23 am
Independent on focus : NO
with focus out of Recordings and Sequencer8 : Yes, with the help of a filter but focus will move too
try a filter folder in the style of
and name it " Sequencer8 "
then in script
File Path ends with \Sampler\Recordings\ and (Title is Sequencer8 or File Name starts with Sequencer8)
then in script
browser_gotofolder 'filters://Sequencer8.vdjfolder' & repeat_start rswt 100ms -1 & get_text "`get_status`" & param_contains 'Searching' ? : repeat_stop rswt & file_count & param_cast & debug & param_equal 0 ? goto_last_folder & get_text Ready : goto_last_folder & get_text Full
geposted Wed 03 Nov 21 @ 9:32 am
Sorry i didn’t quite understand how this script work :( but it could be easer if in browser_folder ‘Recordings’ if i have 8 file with title contains ‘Sequencer’ take me a variable = 1 (and with this variable = 1 i write full) or i have variable = 0 (and with variable = 0 i write Ready)
geposted Wed 03 Nov 21 @ 5:26 pm
Yes It's a little bit complicated:
1) You need to create a filterfolder which displays only files with title "Sequencer8" stored in "Sampler\Recordings\" folder and name it Sequencer8 :
// only in Recordings with title being Sequencer8
File Path ends with \Sampler\Recordings\ and Title is Sequencer8
- previous filter was more complex taking care of filename too -
2) then the script :
It will call the peviously created filterfolder and see whenever there is a file or not :
// change focus to result of filter
// wait for filter ends its search action
// get the number of files
// debug can be remove, just to see if everything went ok
debug &
// depending on result
param_equal 0
// restore initial focus and do action when READY
? goto_last_folder & ACTIONS WHEN READY
// restore initial focus and do action when FULL
: goto_last_folder & ACTIONS WHEN FULL
debug &
param_equal 0
geposted Wed 03 Nov 21 @ 6:17 pm
now i have understand and it work, thanks!
what is wrong in this script:
button: get_browsed_folder & param_contains ‘Recordings’ ? browser_scroll ‘top’ & repeat_start ‘scorri’ 100ms & browser_scroll +1 & browser_scroll ‘bottom’ ? repeat_stop ‘scorri’ : nothing : browser_gotofolder ‘Sampler\Recordings’ & browser_window ‘songs’ & browser_scroll ‘top’
doesn’t work correctly, i would that if i’m already in folder ‘Recordings’, focus scroll down all files; i’m not in folder ‘Recordings’….focus goes to folder ‘Recordings’ and scroll down all files in this folder, can you help me correct script? thanks a lot
geposted Thu 04 Nov 21 @ 7:20 am
In fact you just wanna iterate all files in Recordings whatever the focus can be
(sort of scan the folder)
1) the folder name is internal 'Sampler://Recordings'
2) browsing functions are not instant, you may want them to end before you can use folder content
3) the number of iterations is well known, bottom-top = file_count
focus the content can be either browser_window ‘songs’ or browser_enter
repeat_stop scorri & browser_gotofolder 'sampler://recordings' & repeat_start scorri 100ms -1 & get_text "`get_status`" & param_contains 'Browsing' ? : repeat_stop scorri & browser_enter & browser_scroll top & file_count & param_cast & repeat_start scorri 100ms & browser_scroll +1I added a security loop stop at start as long list can take time and multiple press would do strange things restarting the same loop multiple time
geposted Thu 04 Nov 21 @ 10:34 am
yeah work! but there isn’t a ‘nothing’ after ‘Browsing’ ?
right?
right?
geposted Thu 04 Nov 21 @ 3:47 pm
yes, nothing or "nothing" keyword both does nothing, equivalent in 99% of the situations
side effects can appear using the keyword in rare case or may be needed in some other
because nothing keyword does not actually do nothing it alters the status of parameter
geposted Thu 04 Nov 21 @ 4:23 pm
in this script
where i can add a var ‘sequencerfull’ = 1 if in browser_window ‘songs’ (files scroll) there is a file with title ‘Sequencer8’???
i have tryed that get_browsed_song and param_equal ‘Sequencer8’ is correct script to test file name but i don’t understand where i can add this script fod set var ‘Sequencer8’ = 1
can you help me?
thanks!!
can you help me?
thanks!!
geposted Thu 04 Nov 21 @ 6:38 pm
repeat_stop scorri & browser_gotofolder 'sampler://recordings' & repeat_start scorri 100ms -1 & get_text "`get_status`" & param_contains 'Browsing' ? : repeat_stop scorri & browser_enter & browser_scroll top & set sequencerfull 0 & file_count & param_cast & repeat_start scorri 100ms & set sequencerfull `get_browsed_song title & param_equal Sequencer8 ? true : get_var sequencerfull` & browser_scroll +1
better use global var $sequencerfull though in case deck change
geposted Thu 04 Nov 21 @ 6:56 pm
you’re the top!! it’s work! is there a script to make a button to change the ‘filename’ about a sampler in browser_window ‘songs’ (samples that are in ‘Sampler://Recordings’ folder)?? because browser_songs ‘title’ ‘newname’ changes only the sample title, but not the filename..and browsed_file_rename ‘newname’ doesn’t change directly ‘filename’ but open a ‘change name window’…i would change filename directly with a controller button…can you help me? thanks!!
moderator: Please don't quote entire posts when that post is directly above yours, It just makes a thread a chore to read.
geposted Fri 05 Nov 21 @ 7:41 am
No there is no way to do anything with filenames
VDJ does not allow direct folder or file manipulation by script. (create, delete, rename can't be done by script)
Even recording (only place you can specify a recordFile) need accept by button to be pressed
geposted Fri 05 Nov 21 @ 1:41 pm
can you help me with this script about Pioneer DDj-Rzx release fx lever; this lever have 3 position: 0%, 43% and 100% (this is the numbers that i see in mapping section (see in photo)….
fx lever: param_bigger 40% ? param_smaller 50% ? effect_select 1 ‘beat grid’ & effect_select 2 ‘rmx-echo’ & effect_slider 1 1 50% & effect_slider 2 1 30% & effect_select 3 ‘cut’ & effect_active 3 off & effect_active 1 on & effect_active 2 on : effect_select 3 ‘cut’ & effect_slider 3 1 40% & effect_active 3 on & repeat_start_instant ‘wait’ 4000ms & effect_disable all : repeat_stop ‘wait’ & effect_select 1 ‘mobius’ & effect_select 2 ‘reverb’ & effect_select 3 ‘phaser’
i would that in 0% position reset at my 3 favourite effect (mobius, reverb, phaser); in 43% lever position effects active are beat grid and rmx-echo and in 100% lever position add cut effect, but if i’m in 43% lever position and beat grid effect finish…rmx-echo stops…and if i’m in 100% lever position and beat grid effect finish, rmx-echo and cut effects stops too…i have set repeat_start_instant 4009ms because i have seen that beat grid effect during (lasts) 4 sec; but in this mode only in 43% lever position work well..in 100% lever position i haven’t any effect :
geposted Thu 11 Nov 21 @ 12:13 pm
