Topic: Script School - Page: 32.55
if waiting for end of loop to reloop, just let it loop and not use reloop. Use a rsi to monitor and save inLoop position, if current is smaller than saved then the loop has just restarted and your switches can be reset.
user22183247 wrote :
so if I have a track that has no decent intro to mix with, I could loop the first 1 or 2 bars and use stems to remove the vocals and melody, to get just a rhythm loop, and then exit the loop and re-enable the vocal and melody stems and jump back to the start point of the now exited loop and continue playing the track with the full vocal and melody.
Locodog.. wouldn't this be a great use for your RoutineSP addon?
https://www.virtualdj.com/forums/233820/Addons/routineSP.html?search=routinesp&page=1
Update: Opps.... I see needs vocal stems removed and added back. Then may not be best use
Or could use RoutineSP and only need to do the stems manipulation.
I have a custom button that record a shader for 10 sec and after that it changes to the next shader and then wait 3 sec.
I want to repeat this until the button is pressed again. Is it possible?
record on & wait 10000ms & record off & effect_string ”audioonlyvisualation” 1 +1 & wait 3000ms
deck master repeat_start_instant 'rsiShaderRecord' ? on & record off & deck master repeat_stop 'rsiShaderRecord' : off & record on & deck master repeat_start_instant 'rsiShaderRecord' 13000ms -1 & (  record ? : record on ) & wait 10000ms & record off & effect_string audioonlyvisualisation 1 +1
typo in your visualisation that copied thru but seems there's something in the previous script, it doesn't like to set up the recording for some reason.
use this instead, first shader might not record, but there after will
Ah, now it works. Thank you !!!
Hi! Tell me how to write the script correctly: (deck right filter_selectcolorfx 'noise' smart_pressed)
it should work like this: when you turn the filter knob and hold the button with this script, the noise effect sounds, if you release the button, the noise effect does not sound.
Look at filter_activate
Countdown script went live between xmas & nye, I didn't have time to explain then so I'll do it now, I don't think it needs much explanation, read & try the examples
examples of countdown as a string
repeat_start 'count' ? repeat_stop 'count' : repeat_start 'count' 1000ms & countdown '2022/12/13 00:00' '%HH:%MM:%SS' & param_cast & deck master effect_string 'text' 2
repeat_start 'count' ? repeat_stop 'count' : repeat_start 'count' 1000ms & countdown '2022/12/13 00:00' '%HH:%MM' & param_cast & deck master effect_string 'text' 2
repeat_start 'count' ? repeat_stop 'count' : repeat_start 'count' 1000ms & countdown '2022/12/13 00:00' '%MM|%SS ----' & param_cast & deck master effect_string 'text' 2
repeat_start 'count' ? repeat_stop 'count' : repeat_start 'count' 1000ms & countdown '2022/12/13 00:00' '%full extra Words' & param_cast & deck master effect_string 'text' 2
querying countdown as an int
[note I have text effect profiles, called bignumber & message]
deck master repeat_start Count ? on & effect_active text off & repeat_stop Count : off & effect_active text on & repeat_start Count 50ms &
param_smaller `countdown '2022/12/09 13:59:00'` 10 ?
countdown '2022/12/09 13:59:00' %full & param_cast & effect_string 'text' 2 :
param_equal `countdown '2022/12/09 13:59:00' %SS` "00" !?
effect_string text 3 bigNumber & countdown '2022/12/09 13:59:00' %SS & param_cast & effect_string 'text' 2 :
effect_string text 3 messageBox & effect_string text 2 "it happened" & repeat_stop Count
set_var_dialog $date
fill it with this
2023/01/02 01:00
use a string variable as the date param
repeat_start 'count' ? repeat_stop 'count' : repeat_start 'count' 1000ms & countdown `get_var $date` '%full past' & param_cast & deck master effect_string 'text' 2
with "filter_activate" works, but then all filter_selectcolorfx stop working.
in this pad, as in the photo, everything works, but I do not need all these functions, I only need "noise", and I want to assign NOISE to one pad to control this function in the "PUSH ON" mode.
I don't know what you're asking.
you need to activate the filter_selectcolorfx "Noise" effect when the button is pressed, when we release the button, the effect should turn off.
P.S. thank you for your time
then finish up with
while_pressed
Here's one for you locodog:
I have a video sample (with dialogue) on a pad which I use on a regular basis. When I hit the pad, I manually lower the fader of whichever deck is playing, then return it once the sample has played.
I'd like to automate this process and script it to a custom button so I can use other pad pages and still trigger the sample when required.
So: Play named sample, reduce volume of live deck while it plays, then return volume to full.
Cheers and Happy New Year!
@groovin it's asked for that often, I have that on a button
set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? param_smaller 0.5 `deck 1 level` ? sampler_play 1 & set $volManip 1 : deck all level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? param_equal 1.0 `deck 1 level` ? deck master repeat_stop volManip & set $volManip 0 : deck all level +2%
Thanks but that's not quite doing the right thing.
It's lowering the volume before the sample plays, then playing it, then raising the volume of both decks. Also it needs to play a specific named sample rather than just the first one in whichever bank is selected.
[edit] It only seems to work correctly on one side. With the left deck playing, it does the above, but if I try it with the right deck playing, it behaves differently (doesn't lower the playing deck, oplays the sample right away, then raises the level of the non-playing deck).
I don't know your path "¯\_(ツ)_/¯"
sampler_play FILEPATH & set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? action_deck 1 ? param_smaller 0.5 `deck 1 level` ? set $volManip 1 : deck 1 level -2% : param_smaller 0.5 `deck 2 level` ? set $volManip 1 : deck 2 level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? action_deck 1 ? param_equal 1.0 `deck 1 level` ? deck master repeat_stop volManip & set $volManip 0 : deck 1 level +2% : param_equal 1.0 `deck 2 level` ? deck master repeat_stop volManip & set $volManip 0 : deck 2 level +2%
Or
sampler_play FILEPATH & set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? param_smaller 0.5 `deck active level` ? set $volManip 1 : deck active level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? param_equal 1.0 `deck active level` ? deck master repeat_stop volManip & set $volManip 0 : deck active level +2%
I can put the path in :-)
Second one works correctly, thanks.
@DJElementDJ
i think i understand what you want. I see on your screenshot my "COLORFX" Padpage ;)
check this script. This is the part that you whant. The Problem is. The Color fx whers turn off by using this script. You need an second button to reactivate color fx again or you can not use any other Color FX.
filter_selectcolorfx 'noise' & filter_activate off & filter_activate on while_pressed
Vocal FX Pad Mode Editing :
Hi Guys, I need your help editing a pad page that i find very useful in vdj. Its the Vocal FX pad mode by Rune(DJ In Norway). i want help editing the pad modes so they can be toggled on and off instead of pushed down and release action. and if possible also with LED feedback so you know its on. The pad i am most interested in editing is the LOOPCHOP. Thanks in advance .
P.S : I sent this message initially as a DM to @locodog but it seems he is a bit occupied so decided to put it on here. Thanks
FYI : Just In Case Anyone on here is willing to convert/write scripts for a VDJ Add-on called Sticky for Mac Users, please let me know so i can contact you for help. Thanks
After bring it up to date
down ?
on & set 'VoxFXcount' `var 'VoxFXcount' ?
get_var "VoxFXcount" & param_add 1 : get_text '1' & param_cast val` & set 'voxLoopCycle' 0 & effect_stems 'vocal' on & repeat_stop 'voxRoller2' & quantize_loop on & padfx 'loop roll' 0.9 0.75 & wait 1bt 1 & repeat_start 'voxRoller' 1bt & effect_slider 'loop roll' 2 -20% & cycle 'voxLoopCounter' 2 & var 'voxLoopCounter' 0 ?
repeat_stop 'voxRoller'& repeat_start 'voxRoller2' 1bt & effect_slider 'loop roll' 1 -15% & cycle 'voxLoopCycle' 6 & var 'voxLoopCycle' 0 ?
repeat_stop 'voxRoller2' :
nothing :
nothing :
off & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` :
then change down query to a var query and include 2 toggles of the var
var voiceThing 0 ?
on & toggle voiceThing & set 'VoxFXcount' `var 'VoxFXcount' ?
nothing :
nothing :
off & toggle voiceThing & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` : set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1`
I'm going to have to start charging for this
60%
