Hi all,
Can anyone help? I’m complete newbie with controllers so forgive me.
I thinking of buying Reloop Beatpad 2, but I can only see 2 physical channels on the Beatpad 2, it says it’s a 4 channel integrated usb interface. How does this work? How do you use 4 channels?
Best
Tom
Best
Tom
geposted Thu 20 Dec 18 @ 3:45 pm
Yes there are two physical sliders, but above the sliders are buttons 1 & 2. These will toggle between decks 3 & 4.
It's easier than it sounds, but keep your eyes open as to the position of them when going between decks.
Personally, I like to see 4 sliders in front of me, you always know where you are then.
geposted Thu 20 Dec 18 @ 5:16 pm
4 channels would be 2 decks in stereo. Or perhaps Master and Monitor in stereo, likely the latter.
geposted Thu 20 Dec 18 @ 11:23 pm
