Sharing to facebook should be fixed now.
geposted Wed 14 Sep 22 @ 8:38 am
yes now it works.
geposted Wed 14 Sep 22 @ 8:57 am
Hi Mate,
It's a 502 Bad Gateway at the moment.
Cheers
geposted Wed 14 Sep 22 @ 9:57 am
hello guys. someone pin this message please.
so, in order for a set to be uploaded you need at least 20 minutes and 10 songs. if you have less than 20 minutes you get the problem in the logreport.txt inside the virtualdj folder from your user documents. otherwise, if you have more than 20 minutes but less than 10 songs, you don't get any warning in the logreport.txt, but neither you get the songs uploaded.
best regards.
best regards.
geposted Thu 15 Sep 22 @ 6:50 am
Hi!
Instead of using the history settings, played songs, running time, etc, the fastest and most productive is to use the "Cloud lists" folder. Simply create a list and drag items into it and voilà! Your list will be in your account, in the "Cloud lists" section, without wasting time, without complex math settings, without bothering you. And as Maurice would say, be happy, et cetera, et cetera, Hooray everybody!!!
geposted Sun 13 Nov 22 @ 6:58 pm
