Topic: No Plugins folder in VDJ2021?
Hey guys, couple weeks again I had downloaded VDJ8 I believe and there was a Plugins folder for me to put VST .dll files into. I had to reinstall windows 10 and downloaded vdj2021 but not seeing a Plugins folder in Explorer.
Does this mean VST's are no longer being hosted in VDJ? If yes, is the previous VDJ8 version available anywhere please? Thx.
geposted Tue 17 Aug 21 @ 5:58 pm
still there
C:\Users\user\Documents\VirtualDJ\Plugins64\SoundEffect
COOL, THANKS!
Mind you that 64 bit version of VirtualDJ also requires 64 bit VST's
VDJ 64-bit can use 64-bit VST 2 plugins.
VST3 plugins are not yet supported.
K thx. Any way in VDJ to trigger 2 fx's at the same time on the same deck please like say both a reverb and delay?
Sure, just activate both
Thank you, works!
