Hey guys, couple weeks again I had downloaded VDJ8 I believe and there was a Plugins folder for me to put VST .dll files into. I had to reinstall windows 10 and downloaded vdj2021 but not seeing a Plugins folder in Explorer.
Does this mean VST's are no longer being hosted in VDJ? If yes, is the previous VDJ8 version available anywhere please? Thx.
geposted Tue 17 Aug 21 @ 5:58 pm
still there
C:\Users\user\Documents\VirtualDJ\Plugins64\SoundEffect
geposted Tue 17 Aug 21 @ 6:05 pm
COOL, THANKS!
geposted Tue 17 Aug 21 @ 6:23 pm
Mind you that 64 bit version of VirtualDJ also requires 64 bit VST's
geposted Tue 17 Aug 21 @ 6:36 pm
Can anyone recommend any specific version of VDJ which will definitely work with 64bit VST's please as the lates version does not work with this 64 bit versions?
https://i.postimg.cc/RFw5kFnd/IMG-3790.jpg
https://i.postimg.cc/7LDW5VC3/IMG-3791.jpg
geposted Tue 16 Aug 22 @ 4:06 pm
VDJ 64-bit can use 64-bit VST 2 plugins.
VST3 plugins are not yet supported.
geposted Tue 16 Aug 22 @ 4:09 pm
K thx. Any way in VDJ to trigger 2 fx's at the same time on the same deck please like say both a reverb and delay?
geposted Tue 16 Aug 22 @ 4:58 pm
Sure, just activate both
geposted Tue 16 Aug 22 @ 5:30 pm
Thank you, works!
geposted Wed 17 Aug 22 @ 12:13 pm
