Forum: Old versions
Topic: not working!? cracked version
hi my virtual dj works like shit, could it be because i got a fake serial? from a downloaded version? or
geposted Sat 13 Sep 08 @ 9:27 pm
haha! Muppet
Please download the demo and see the difference.
Crack versions are not reliable at all.
Like Jimmy B said download the trial and see for yourself.
I am sure once you see how much better it is you will
purchase a legitimate version.
ive used a cracked version of numark cue before and it was rubbish i think ill just stick to my VDJ!!!! when the cracker cracks the file they have to edit the actuall .exe file and taking out bits of code here and there will always be unstable unless you wrote the program of course!
its still not working, sounds like shit and says 0% signal with my timecode.. please i got a emu 1820m soundcard, is that not supported or something?
If buy the legal version most of your problems will be solved.
And more guys will be willing to give you a hand.
I wouldn't complain about things sounding shit, or not working properly when you are using a cracked version. Get real mate - i know we are meant to be civil to unlicensed users but its very hard when they come on here demanding things and bagging the software.
I have been there - i used cracked software then bought VDJ and haven't regretted it all. I hope you and other unlicensed users do the same.
im using this goddamn demo now, and its still shit
Pls delete fully ur previous version n just have the legit demo on ur PC.
Anyway what type of tt, cartridges , TCV vinyl u using?
Have you thought, it may not be the program, but your system it's on!!!!!!!!!
It might help if you be a bit more descriptive in how you have things setup.
For one, you have a lot of options in configuring just your soundcard. You may have things setup incorrectly in your soundcard that is impeding the signal quality. Second, it would be helpful if you provided the VirtualDJ settings from the Soundcard tab and the Performance tab, to better understand how you have that configured. And last, as mentioned - what are your system specs?
Provided u set up everything correctly, in performances tab, try this ..go slide performances to fastest, set auto on latency n untick both safe mode n overclock. Press auto config on the timecodes config couple of times. Abt the dj control it should be able to work in the latest verion too. Enable it in the control configs;)
