hi my virtual dj works like shit, could it be because i got a fake serial? from a downloaded version? or
geposted Sat 13 Sep 08 @ 9:27 pm
haha! Muppet
geposted Sat 13 Sep 08 @ 10:15 pm
Please download the demo and see the difference.
geposted Sun 14 Sep 08 @ 3:55 am
Crack versions are not reliable at all.
Like Jimmy B said download the trial and see for yourself.
I am sure once you see how much better it is you will
purchase a legitimate version.
geposted Sun 14 Sep 08 @ 6:57 am
ive used a cracked version of numark cue before and it was rubbish i think ill just stick to my VDJ!!!! when the cracker cracks the file they have to edit the actuall .exe file and taking out bits of code here and there will always be unstable unless you wrote the program of course!
geposted Sun 14 Sep 08 @ 1:46 pm
its still not working, sounds like shit and says 0% signal with my timecode.. please i got a emu 1820m soundcard, is that not supported or something?
geposted Sun 14 Sep 08 @ 6:47 pm
If buy the legal version most of your problems will be solved.
And more guys will be willing to give you a hand.
geposted Sun 14 Sep 08 @ 7:07 pm
I wouldn't complain about things sounding shit, or not working properly when you are using a cracked version. Get real mate - i know we are meant to be civil to unlicensed users but its very hard when they come on here demanding things and bagging the software.
I have been there - i used cracked software then bought VDJ and haven't regretted it all. I hope you and other unlicensed users do the same.
geposted Sun 14 Sep 08 @ 8:14 pm
im using this goddamn demo now, and its still shit
geposted Mon 15 Sep 08 @ 5:56 am
Pls delete fully ur previous version n just have the legit demo on ur PC.
Anyway what type of tt, cartridges , TCV vinyl u using?
geposted Mon 15 Sep 08 @ 6:02 am
Have you thought, it may not be the program, but your system it's on!!!!!!!!!
geposted Mon 15 Sep 08 @ 9:23 am
It might help if you be a bit more descriptive in how you have things setup.
For one, you have a lot of options in configuring just your soundcard. You may have things setup incorrectly in your soundcard that is impeding the signal quality. Second, it would be helpful if you provided the VirtualDJ settings from the Soundcard tab and the Performance tab, to better understand how you have that configured. And last, as mentioned - what are your system specs?
geposted Mon 15 Sep 08 @ 10:00 am
i got a http://www.thomann.de/dk/american_audio_ttd_2400.htm tt, and the virtual dj timecode vinyl, and the emu soundcard
i got vista, maybe thats the problem, but virtual dj somehow get a signal from the timecode, it just says 0% and doesnt work proberly
geposted Wed 17 Sep 08 @ 1:12 pm
oh btw, just bought this for 100 euro http://www.thomann.de/dk/hercules_dj_control.htm and it doesnt work with the newest version of virtual dj, but it works fine with an older version
geposted Wed 17 Sep 08 @ 1:53 pm
Provided u set up everything correctly, in performances tab, try this ..go slide performances to fastest, set auto on latency n untick both safe mode n overclock. Press auto config on the timecodes config couple of times. Abt the dj control it should be able to work in the latest verion too. Enable it in the control configs;)
geposted Wed 17 Sep 08 @ 4:26 pm
