I'm loving the ability to finally map the DAC2 exactly the way I want it! VDJ 6.0 rocks!
BUT... I really enjoyed the way the outer jog wheel worked by default under previous versions and I can't figure out the VDJScript to recreate that functionality (basically seek forward or backwards through a track at increasing speed the further you twist the wheel).
Any ideas? TIA!
Any ideas? TIA!
geposted Sun 31 May 09 @ 9:02 pm
How u do that?
Would you mind sharing the xml file?
Thanks bro!
Thanks bro!
geposted Sun 31 May 09 @ 10:10 pm
Look in the Manual (My Documents/VirtualDJ) and at the Wiki here -- https://virtualdj.com/wiki/VDJscript.html
geposted Sun 31 May 09 @ 10:59 pm
I read over the Wiki but It does not go into much specifics.
Has anyone been able to add any functionality to the outer_jog wheel?
geposted Fri 19 Jun 09 @ 9:30 am
Yup, same problem here bro! Got everything working except that outer jog!
geposted Sat 20 Jun 09 @ 3:37 am
I've been looking for this too.
geposted Sat 20 Jun 09 @ 10:07 am
I would gladly PAY pern to make a XML version of his DMC-1/DAC-2 mapper.
Until then, using V6 just is not going to happen. I don't have time to learn a new controller and/or configuration at the moment.
What about a DLL > XML translator? :)
Concerning the outer wheel, here is what I would like...
Turn to the left - cycle thru Effects and a turn to the right would cycle thru Samples.
But the inner wheel would like as on the pern mapper.
geposted Sun 21 Jun 09 @ 6:41 pm
If you guys are interested I upload the mapper I have so far. I have almost everything mapped and it's functions pretty decent...
Except for the outer wheel.
Shame to not use 6.0 because of lack of new mappers.
Is anyone interested?
geposted Sun 21 Jun 09 @ 8:24 pm
I am game. :)
geposted Sun 21 Jun 09 @ 9:08 pm
I forgot to say - Please and Thank you! :)
geposted Mon 22 Jun 09 @ 8:44 am
FYI:
I am working on my DMC-1/DAC-2 mappers.
But i just got to much work at the moment. I'm running my own business in Software Development and got some projects that must be finished yesterday. So i'm working 24/7 with these. This is the reason for the delay, sorry about it.
geposted Mon 22 Jun 09 @ 9:12 am
This should work for you in the meantime.
https://virtualdj.com/addons/8392/DAC-2_Mapper.html
Ask and ye shall receive.
geposted Mon 22 Jun 09 @ 9:20 am
I am not worthy....
"Sorry, you don't have the necessary accreditations to view this page."
@ pern - thanks bro.
geposted Mon 22 Jun 09 @ 9:29 am
I just uploaded it. It might take a day to become active. Just check the plugin page and it should be there when it gets approved.
geposted Mon 22 Jun 09 @ 11:16 am
Would you mind emailing it?
I am rather anxious to try and play... :)
geposted Mon 22 Jun 09 @ 4:01 pm
Thank bro.
Seems to have potential w/ me. But will wait to see if DMC-1 is feasible. Otherwise, I will need to learn/practice on the DAC-2 and then install to my gig rig.
But much thanks!!!!
Might switch to V6 during a slow time (after back up system).
But much thanks!!!!
geposted Wed 24 Jun 09 @ 11:00 pm
I also got my DAC2 to do what I want it to do BUT same thing. The outer jog wheel. Please let me now the command placed in the mapper for the jog wheel
geposted Sat 25 Jul 09 @ 5:45 pm
Yeah still not working for me. For anone interested though, I do have my mapper up now if anyone needs it. Still not outer jog though.
geposted Sat 25 Jul 09 @ 5:50 pm
Wow, still nothing on this! I go the DAC2 to do stuff I always wanted. and to display on the LCD when in loop, effects and so on. BUT the outer wheel has no life!!
The inner wheel does the search/pitch blend. Not good when in vinyl mode. I perferr to use the TCV for that.
Please someone post the command for outer wheel.
Thank You.
Thank You.
geposted Wed 29 Jul 09 @ 7:53 pm
The DMC-1 is working just dandy - but do miss the outer wheel.
geposted Wed 29 Jul 09 @ 9:41 pm
