The same with me.
Everything works fine with de DAC-2.
But I really miss the function of the outer wheel.......
It's a simple code i have to fill in, but I can't find it.
Can someone help me/us?
geposted Thu 30 Jul 09 @ 1:10 pm
here the same.
I've the DAC-2 with VDJ 6 and the new mapper.
Can some find out what the command is to seek true the song with the outer wheel????????
I think you would help many people, including me!
geposted Fri 31 Jul 09 @ 4:31 pm
I just upgraded to 6.0 and have the same problem with the Dac 2, no outer jog wheel or BPM or Time remaining on the display of the Dac. I I havn't been on the VDJ Site for several months and see that all the posts on this topic are from June. No updates since then. Does this mean nobody has been able to properly map the outer wheel on the Dac 2?
geposted Thu 13 Aug 09 @ 9:05 am
Correction on the dates of the posts. Just noticed the previous post was Aug. 9th. So this is still a problem. Anyone getting close yet?
geposted Thu 13 Aug 09 @ 9:06 am
downloaded dgruetter's Dac 2 mapper and when I hit the .exe file, goit a message saying "make sure Dac 2 is connected to USB port". It was so I hit ok. Then opened VDJ ver. 6 and it seems the mapper that came with ver. 6 is still there. No change as far as functinality. Do I have to somehow select or turn on dgruetter's Dac 2 mapper and if so how? I want to get BPM, Time remaining and outer jog wheel working and am hoping his mapper solves these problems(except for the outer jog wheel as it seems no one has solved that problem yet).
geposted Thu 13 Aug 09 @ 9:49 am
There shouldn't be an .exe in the download file. Just a Zipped .XML file. Just unzip it into \VirtualDJ\Mappers and replace the default mapper (which I believe is blank anyway). Then all you need to do is make sure you select "use serial devices" in the mappers section on the options screen. Then it should work.
geposted Thu 13 Aug 09 @ 10:10 am
Thanks, it's working better now. I can see the BPM's and elapsed time. Is there a way to see time remaining instead of elapsed time?
geposted Thu 13 Aug 09 @ 10:24 am
Try the readme
I think it explains how to change it.
geposted Thu 13 Aug 09 @ 10:26 am
Thanks. All set. Now if only someone can figure out the outer jog wheel and video transition bug, ver. 6 should be solid.
geposted Thu 13 Aug 09 @ 10:53 am
Yeah, I can live without the outer wheel but it would be nice to have full functionality of the dac-2.
geposted Thu 13 Aug 09 @ 12:32 pm
yes....
thats what i need too
geposted Mon 17 Aug 09 @ 4:06 am
I'm also a registered user... whose VDJ6 sits in a folder... uninstalled... until somebody with the code-smarts I DON'T have gets the DAC2 jog wheels to work like it did in VDJ5 :( Soon, I hope... keep us posted !
geposted Tue 06 Oct 09 @ 8:59 am
HI this works in 6.0.4
map OUTERWHEEL to this action
param_smaller 0.01 ? seek -64 : param_smaller 0.08 ? seek -32 : param_smaller 0.15 ? seek -16 : param_smaller 0.22 ? seek -8 : param_smaller 0.29 ? seek -4 : param_smaller 0.36 ? seek -2 : param_smaller 0.43 ? seek -1 : param_smaller 0.52 ? seek 0 : param_smaller 0.58 ? seek +1 : param_smaller 0.65 ? seek +2 : param_smaller 0.72 ? seek +4 : param_smaller 0.80 ? seek +8 : param_smaller 0.87 ? seek +16 : param_smaller 0.94 ? seek +32 : param_smaller 1.1 ? seek +64 : nothing
geposted Thu 03 Dec 09 @ 6:01 pm
Awesome job thanks lopez453!
geposted Sun 13 Dec 09 @ 3:36 pm
Lopez thats brilliant mate, well done.
A new one for you, How can I get the 'Wheel' just to browse up and down track list, and not do anything during Play?
Many Thanks
Goochie.
Many Thanks
Goochie.
geposted Thu 15 Jul 10 @ 6:15 am
You mean the OUTER WHEEL or the inner WHEEL ?
geposted Tue 20 Jul 10 @ 5:25 am
I assume he means the outer wheel.
dgruetter, you think you could send me/post the mapping XML for the DAC 2? It would be a great help...
geposted Fri 17 Sep 10 @ 9:09 pm
Just check the plugin section to download it. I cannot email anyone the mapper sorry.
geposted Fri 17 Sep 10 @ 9:26 pm
Please DO NOT ask our registered users to send you add-ons to which you are not currently entitled to.
You will need to purchase and register VirtualDJ Professional to be able to download mappers and other add-ons: https://virtualdj.com/buy/
geposted Sat 18 Sep 10 @ 2:22 pm
