Forum: VirtualDJ Plugins
Topic: SBDJ Notepad - Page: 1
v1.0 of this plugin has been uploaded.
Requirements: VirtualDJ Professional v7.0 or later
This is a fairly new class of plugin for me - and others it would seem too. It appears on the plugins page under "Others" as SBDJ Notepad. As you can see there is a text input window and three buttons.
The filename is automatically chosen and saved in the Documents\VirtualDJ folder. The filename is based upon the date and time that the current VDJ session was started.
Since this page is a pain to navigate to in a hurry, another option exists. A popup window can be displayed from the plugin page. The plugin also monitors the variable $sbnotepad_show. Currently the following actions exist:
set '$sbnotepad_show' 1              Opens the notepad popup
set '$sbnotepad_show' 2 Opens the notepad popup maximised
set '$sbnotepad_show' 3 Closes the notepad popup
The plugin does not require activation - once installed it runs *all* the time that VDJ is running. To disable you have to remove it from the Plugins\Others folder.
The plugin also creates an ini file that stores the popup window location and dimensions. You can also modify the font size in this file.
Let me know what you think, once (if) it is approved by the team.
geposted Tue 12 Oct 10 @ 8:02 pm
Super Job!! Works just how I thought it would!!
Thank You and great Job!!
Huey
Cool :)
Slowly working through my to-do list!
Man this is a blessing!! I have used it to store the commands for making Filter Folders cause I always forget the script, lmao!!
Thanks again
Huey
Maybe I'll add some tabs at a later date. It was aimed at being simple though - pop up, write, save if you want kinda thing. No complexity ;)
Dont get me wrong, the easier to use the happier I am!! Come on youve delt with me before, lmao!!
Huey
I have just installed this but am having problems locating it, I'm obviously doing something wrong, I'm a novice level can some one please give me some guidance as to how I can find it, I'm using the basic skin. This would be a useful feature for me
Plugins\Others
1 thing that keeps happening now is, when I open it it always shows the last note. How do I get it to display an empty sheet everytime?
Huey
Thats the whole point though isn't it, you don't want the notes to disappear every time you save or close the window do you?
I could easily add a clear button or some other way of clearing?
Yeah your right, lol! I think a clear button would be nice though. Then I could clear it out after I have saved it or eles it would just keep adding too.
Thanks for your time
Huey
Love this plugin.
I use if for requests etc so I wouldn't want a blank page everytime.
However a clear button would be good at the end of or beginning of a gig. :-)
The VDJ community is glad to have people like SBDJ, TexZK, DjCel (i certainely forget a few more), who with theire knowledge and creativity make this wonderfull software even better, even easier and even usefull !
Thank you all.
Great plugin mate.. it will certainely make my djlife easier, and i hope that your ToDoList is long enough to make everyone happy !
Just a quick question for SBDJ does this save the notes if the laptop was to crash.
For example if I used it to make a note of requests and the laptop crashed would I lose the list?
Running Windows 7 if it makes a difference
If you click save, then no, all text will be saved to a file automatically.
Adding an autosave would be trivial... :)
djcel wrote :
Plugins\Others
I think what you mean is : Effects\Others ?
No, it is for example: "C:\Users\<USERNAME>\Documents\VirtualDJ\Plugins\Other"
Scott, it really ROCKS!!!!! something I've been using as a separate plug in, now inside the VDJ.
Thanks for your help.
BTW, I using it just to have some lyrics and many others signs to be displayed at night.
Cheers
Ju@n
Wow,
Love this plug-in.
Finally I can get rid of my papers.
I'll carry a few documents with tips & tricks on music choices, customer demands & requirements ....
If you could build in tabs and make that for each tab we can load another document, this feature would become a super tool (although it is that already)
Don't know if this is possible.
1e tab: tips & tricks
2nd tab: customer requirements
3th tab: music requests (on the fly requests)
4th tab: keyboard shortcuts
The number of tab tabs shown could be in the ini file
Thanks for looking to it.
Regards,
Johans
27%
