Forum: VirtualDJ Plugins
Topic: SBDJ Notepad - Page: 4
The notepad is found at the plugin tab.
Sorry, i didnt realize my second screen was there
i know where i find the plugin...
but i did not get an additional window..which i should get ....
Thanks for that screenshot - that appears to be an older version that I have here so I'll test it and upload an updated version in the very near future.
The newer version just uses a popup, it doesn't bother with the hassle of the double window setup.
Am I correct that I have the current version available?
Thanks again for your time.
I believe so. I'll get an updated version sorted over the next couple of days.
Scott,
If I create a text file with Windows notepad (i.e one line of text on each line, like a list of top 100 disco tracks) and then import it into your notepad plugin, all the formatting is lost, and all the text is in one string ........... Any ideas ?
Any chance of a version of this VDJ 8?
+1
Please SBDJ ,I Love this Notepad Plugin too
for the Music Wishlist of the Guest
thanks forward
greatings,Dirk
Hello SBDJ!
Gives some news for this Plugin
Do you work eventually on a Notepad Plugin for VDJ 8 ?
greetings and thanks ,Dirk
Won't this do what you want?
@locodog
thx for pointing this out.
@locodog:
No
I use this as Wishlist for the Title of Music by Guest.
When someone comes to me and have a Title what i soll play than i write this in the Notepad List,for later Time when the Title are comes in my Playlist to the right Time and i not forget him.
greatings,Dirk
Wouldn't it be easier to set these titles apart in a separate playlist or the sidelist directly, instead of fully typing the names and then having to go search for them before you can play them?
Indeed it would. But sometimes you just don't want to search for a song while the guest is standing next to you. There are plenty of reasons why you would do that.
So you need a place to write down the track.
