Is there away to take off the info tab....
geposted Mon 12 May 14 @ 9:26 am
Did you mean completely remove from the skin, or undock it from the skin an drag it somewhere else?
Or just collapse it?
geposted Mon 12 May 14 @ 9:28 am
You can't remove it completly in the full browser. You can close it.
Skin developers can now split the browser into sections so yes it can be removed in a custom skin.
thanks ......
geposted Mon 12 May 14 @ 9:34 am
