groovindj wrote :
What's the hex code for that glowing green colour?
http://rapidtables.com/web/color/RGB_Color.htm the chart I use & I only did the top 1/2 and the music browser what Ok with the color ( #6BCA19" GREEN ).
geposted Mon 18 Aug 14 @ 7:26 pm
Now if we could only get the red & blue colors changed......
geposted Thu 21 Aug 14 @ 2:16 pm
You can - if you edit the graphics file.
geposted Thu 21 Aug 14 @ 4:36 pm
I tried and the results were not good
geposted Thu 21 Aug 14 @ 5:37 pm
Hey could you also create a function that disables and enables the visibility of the sync button?
geposted Sat 23 Aug 14 @ 2:01 pm
is it possible to use the 4deck with the 4 scratchwaves under the decks? thank you
geposted Sat 23 Aug 14 @ 5:45 pm
Just to let you know I'm reading carefully every suggestion.
- get rid of red/blue
I will propose a version of this in a separate xml/png layout, but only when the skin is finished
- disable sync
Well you may still can sync with keyboard / controller so it would just make the button disappear, why not but I don't promise on this.
- 4 decks waves
Can you be a bit more accurate on this ? Do you mean 4 full length scratches below the whole 4 decks ? Dunno if I can put a browser below all those stuffs lol... Or do you mean something else ?
- disable sync
- 4 decks waves
geposted Sun 24 Aug 14 @ 1:12 pm
- disable sync
- 4 decks waves
- disable sync
- 4 decks waves
About the sync, that's exactly what I'd like. As a DJ I just hate to even see the sync button so an option to hide it would be great. The other scratch djs like myself would appreciate this feature also
geposted Sun 24 Aug 14 @ 11:00 pm
Would you like to see another button instead ? (which one)
Or a blank space ?
Or a blank space ?
geposted Mon 25 Aug 14 @ 4:02 am
Or a blank space ?
Or a blank space ?
That could be up to you, don't really know what to replace it with so I'd say blank space.
geposted Mon 25 Aug 14 @ 7:08 am
Hi Friut, is now also avaiable as a 4-deck-skin?
(Maybe with the alternative to switch from 2 to 4)
Thomas
Thomas
geposted Tue 26 Aug 14 @ 12:57 am
Yes but I didn't really work on the 4 decks version so for now it is almost the default 4 decks skin with some customized colors according to the 2 decks skin. I will improve the 4 decks version the same way I'm actually doing on the 2 decks one.
geposted Tue 26 Aug 14 @ 2:28 am
Hi Fruit,
Discovered a serious bug in your skin ..... if you go to tablet mode and back (as I have a touchscreen Yoga) it wipes all the settings you made in 2 deck mode.
It's a pain to have to go and configure all the skin options every time.
Keith
Keith
geposted Fri 29 Aug 14 @ 3:20 pm
Hello Fruit
any chance you might implement something similar to this
the part that interests me is the wave display with the numbers. its an option you can turn on called pioneer style.
this image is from the Hercules RMX2 Black by djdad
geposted Sun 31 Aug 14 @ 12:46 pm
Yup 0.6 will bring 3 or 4 different songpos styles.
geposted Sun 31 Aug 14 @ 5:30 pm
kradcliffe wrote :
Hi Fruit,
Keith
Keith
I'm afraid but it is not a bug. The skin engine doesn't keep the panels states after changing skin / layout.
But as said earlier in this thread I will bring a 'stance SDK' that would name all the options / panels so that you're able to set a custom button to get your preferred stance at once. I also will bring a bunch of five custom buttons especially intended to set 5 stances of your choice.
geposted Sun 31 Aug 14 @ 5:37 pm
Hi Fruit, Thanks I think I work it all out with the skin you made,I have more ideas but can't make skins...lol
Im trying to get more comfortable using VDJ-8 like VDJ-7 Thank YOU FruiT
geposted Mon 01 Sep 14 @ 4:51 pm
Well done bro, but I'm afraid you'll have to do this again in next version !
Coloring should be easier thus.
Cheers :)
Cheers :)
geposted Tue 02 Sep 14 @ 8:03 pm
I made a 2nd copy with diff name,but when/if your update comes it will not effect that FruiT remix skin.
geposted Wed 03 Sep 14 @ 9:22 am
Yes but you'll want to mod the new one, trust me :)
geposted Wed 03 Sep 14 @ 12:21 pm
