Can you explain the how to use the "loop load prepared" function because with this skin version, I can not save or activate them, with the one before it worked very well , even with the original skin I can not do it , I have to remove the skin to make it work again , can you enlighten me please
geposted Wed 04 Mar 15 @ 4:31 pm
I'm not saying that the reason inverted ways are not present any more is due to the fact that you can move the needle mark ("earline" for Frut)
However, skinwise it's not that simple because in version 8 you can overlay any graphic you wish as your needle and that graphic does not need to be "centered" too!
Take a look on this snapshot:
The needle is placed on 1/3rd of the available rhythm width. Also it has an overlay on the "played" part (it's darker).
Graphicwise, this is a simple graphic overlay that's NOT centered on the needle position. If VirtualDj would programmatically try to "reverse" this then the needle would be presented wrong.
That case should be taken care of the skinner itself. In other words the skin creator should query the settings if the rhythm is reversed or not, and accordingly use different graphics.
Anyways, I don't wish to hijack Frut's topic any further and I believe you have made your point.
It's up to the devs now if they're going to bring back the reverse option or not.
So I believe we can all "calm down" now :)
geposted Wed 04 Mar 15 @ 4:41 pm
I'm not sure this is a total highjack, as Fruit seemingly was interested in this aspect from a programming standpoint, as well.
Regardless, what I understand you to say, is pretty close to what I was speculating? If so, maybe Fruit and I can figure out how to simulate it?
geposted Wed 04 Mar 15 @ 7:43 pm
You can't reverse the direction at the moment, so no, you can't simulate it.
If you were able to reverse then the skinner could query the settings to see if the direction is reversed or not. But that's a big IF
geposted Thu 05 Mar 15 @ 6:18 am
I see. When Fruit spoke "inverting" the wave, I pictured him standing it on it's head, which in theory would also reverse the direction of movement.
geposted Thu 05 Mar 15 @ 10:39 am
Sorry I meant 'inverted movement's direction' of course (and was just supposing unreal things).
geposted Fri 06 Mar 15 @ 2:23 pm
Oh, well. Your heart was in the right place.
geposted Fri 06 Mar 15 @ 8:48 pm
alixrippon971 wrote :
Can you explain
I answered this by pm :)
geposted Sat 07 Mar 15 @ 3:37 pm
thx fruit
geposted Mon 09 Mar 15 @ 5:55 am
hi m8 just update virtual dj and now your skin on the right deck come up with a white patch on it can you help me fix it. your skin are the best m8
geposted Fri 13 Mar 15 @ 3:18 pm
Yes it is a known bug.
What you may try now is :
If you activated the 'art' option on jogwheel (menu deck / wheel / art), try to disable it THEN RESTART VDJ. It should avoid the bug.
If you still encounter it, another solution is to disable the songpos wheel option (menu deck / wheel / songpos). But you will loose some info on wheel so the first workaround is to be tried priorly.
geposted Sat 14 Mar 15 @ 10:11 am
I think that's just to be expected, until Atomix can work out the cause. Mine does the same, if I use the two deck view.
geposted Sat 14 Mar 15 @ 4:43 pm
They told it's me having to update the skin, so I provide some quick workarounds in the meantime.
geposted Sun 15 Mar 15 @ 6:59 am
Hi Fruit, hope u r well
I would like to ask if it is possible for you to put a right click option onto the HOT CUE button to toggle the lock feature on and off, and then maybe have the words light on/off so that it looks like the little padlock.
edit
or maybe just move the padlock up onto the big HOT CUE button
It's not a big thing, would just save me some mouseclicks, as I have all my songs locked by default.
thx & best wishes
ray
edit
thx & best wishes
ray
geposted Mon 16 Mar 15 @ 6:02 am
- todo list :)
geposted Mon 16 Mar 15 @ 6:56 am
merci
geposted Mon 16 Mar 15 @ 7:18 am
the skin the not work for me how i fix it
geposted Tue 21 Apr 15 @ 3:40 am
Hum,
Could you explain that a bit please ?
geposted Tue 21 Apr 15 @ 11:09 am
Unable to download...
Sorry, you don't have the necessary accreditations to view this page.
geposted Fri 01 May 15 @ 8:14 pm
The link on page 1 is the old link. Things got moved around by staff.
Use the link on page 18 instead, or the Download menu above - DOWNLOAD/Addons/For VirtualDJ 8/ make sure Skins is selected, and search for 'fruit'.
geposted Sat 02 May 15 @ 7:04 am
