Fruit ...you are the man.
This is the best VDJ skin, by a wide margin. I've modified it slightly for my own use, but you've done a great job as usual.
I'm satisfied that they will not... but by all rights, the company should get behind your efforts, and provide you with professional tools ...at the very least.
Keep up the good work... you are appriciated out here :)
geposted Tue 31 Jan 17 @ 4:52 pm
TY Rich ^^ goes right to my heart !
And I hope some day you will come back among us, just because VDJ is now able to show some 'from left' waves, that no other software in the world can do, really.
geposted Tue 31 Jan 17 @ 4:55 pm
locodog wrote :
Great update, ..Downloaders, don't forget to rate this after you've checked it out.
Where is the rating poll because I will give his skin 100% approval like rating.
geposted Tue 31 Jan 17 @ 5:02 pm
ohshit wrote :
Where is the rating poll because I will give his skin 100% approval like ratings.
geposted Tue 31 Jan 17 @ 5:04 pm
It is on the addon's page, just below the addon's creator name.
geposted Tue 31 Jan 17 @ 5:08 pm
You are very welcome, but regarding the WFD... Serato Itch does a very good job of it, with their vertical WFs moving up the left side.
The layout is very logical, with the WFs being located properly (left & right, vs up & down), as well as traveling in unison with the grooves on the left side of the records.
I've grown to like it very well, not to mention the much superior visual quality of Serato's waveforms.
Anyway, carry on... You are doing a fantastic job working with what you have.
geposted Tue 31 Jan 17 @ 5:12 pm
This skin should be voted as the default skin! I've said it so many times! This is what Virtual DJ users should be using! Custom buttons, video layout, 4 effects per deck and 6 master effects! FRUiT took DJing to another level with this skin!!!! Great job!!!
geposted Tue 31 Jan 17 @ 5:46 pm
Hahaha ty my n°1 fellow tester !
You involved so much time in trying and debugging (and I know you also spend time to help in hidden areas in the meantime) ! Really, you deserve one more star ^^
geposted Tue 31 Jan 17 @ 6:41 pm
geposted Wed 01 Feb 17 @ 12:03 am
BIG thank you for this.
Great work ;o)
Great work ;o)
geposted Wed 01 Feb 17 @ 6:09 am
Many of the buttons in the browser set off "browser zoom". Both scroll up buttons and the side window buttons activate "browser zoom" with the new update.
geposted Wed 01 Feb 17 @ 8:21 am
Hi kidmixx,
try turning the device managed option off
hope that helps
ray
hope that helps
ray
geposted Wed 01 Feb 17 @ 10:10 am
raypitman wrote :
hope that helps
Yes it should ! Ty Ray :)
geposted Wed 01 Feb 17 @ 10:47 am
To get further I reported what to me looks like an issue...
https://fr.virtualdj.com/forums/214783/VirtualDJ_8_2_Technical_Support/Sidelist_and_browser_isactive.html
I don't know if it's been added in todo list or it's still a feature...
geposted Wed 01 Feb 17 @ 6:41 pm
Do I also get a a recomendation for another star , I would so like to have one... LOL & :-(
1. Do you notice any high CPU levels with the new skin, some of the guys on another forum are commenting on it?
Personaly I just think that if you want to have top performance, you gotta have a big engine, or, enough money to buy a Tesla. On my system the CPU is always way down in 20-30% range.
2. Would it be possible to get all of the posts onto just one page, at the moment it's hard to keep up with both of your sides, you know .. addons & skins ?
geposted Wed 01 Feb 17 @ 8:45 pm
If I could, I would've made you a staff member ★★★★★★★★★★★★★★★★★★★★★★★★★ ^^ lol
Afaik, no the skin doesn't require more cpu than 0.7 once it's loaded and ready. Mine is ~7~13% when idle. What is true is : the skin is a bit more memory hungry than its predecessors or other skins (~720MB used) that's why the skin is a little bit longer to load. Other than that there shouldn't be any issue with cpu usage / performance.
Yea that's a concern... I don't know what to do. Plus I have a third thread in the french area.
geposted Wed 01 Feb 17 @ 10:11 pm
Maybe the moderator can close one thread and ask forum participants to use the other thread in the English forum ? imho
geposted Wed 01 Feb 17 @ 11:13 pm
In theory each thread has it's own different purpose.
On the other hand we are not fans of strict moderation.
Therefore, let it be.
After all it's just a heat up because of the recent release of the new version. It will settle down in a few days and each thread will go back to it's normal traffic and closer to it's real purpose.
geposted Wed 01 Feb 17 @ 11:23 pm
I wouldn't even know which one to close, both of them handle half part of the skin's visibility... I think the addons comments are not visible enough, and too much separated from the forum. Unfortunately it's the only one that can't really be closed because of the skin page link. Then it would mean to delete this one in skin forum, kind of a dilemma. I want to keep that one.
I've never catched why the addons forum is not visible on the main page between the plugins forum and the skins forum.
And +1 Phantom ! :)
And +1 Phantom ! :)
geposted Wed 01 Feb 17 @ 11:31 pm
true, the addon board being missing from the main forum board is a little confusing [ I can remember when I first found it I thought I'd found a forum loophole for NLU's] [I've tested lots, I can still access the 8.0 beta board, {exe's are way better than .msi's for back cheking} ]
Either addons needs to be visible or skins & or plugins needs to announce releases
geposted Wed 01 Feb 17 @ 11:52 pm
