It is ON the tab ITSELF (where you click to show the monitor), not inside the panel, look carefully at the left of the word 'MASTER', the small icon becomes red.
I guess it is not intuitive enough, will think about a better way to show it.
geposted Thu 10 Jul 14 @ 10:08 am
Got it !!! wow that is discreet but clever!
geposted Thu 10 Jul 14 @ 10:09 am
Also, but I have no time now as I'm in holliday,
The center area of the 'per deck' waveform views will be greatly improved to show several usefull things in a fashion menu, instead of the current master's monitoring vu-meter.
geposted Thu 10 Jul 14 @ 10:13 am
Since you have mentioned the size of the xml in bytes, worths stating here, that the size of the xml has nothing to do with the performance and the cpu usage.
It mostly depends on the elements you are using. For example, panels are great cpu eaters. Too many visibility actions , Visuals, rotating parts, waveforms are cpu eaters as well.
geposted Thu 10 Jul 14 @ 8:28 pm
Sounds more like a development team issue than a skinner issue.
The internal code needs to be optimized so that no elements of the skin become "cpu eaters".. Also the code should be optimized so that no skin is allowed to slow down the performance of the software.
geposted Thu 10 Jul 14 @ 11:56 pm
So if I understand well, even a 'actually hidden' panel stills eat CPU ?
Also, in the example of the deckbar, only one panel is defined, but it is called twice. Does it eat cpu as one panel (define beacon) or two panels (called twice later in the xml) ?
geposted Fri 11 Jul 14 @ 3:58 am
Thanks team for having improved the cpu tooltip !
I compared a bit my skin with the default internal one.
I must say that mine eats ~10% more 'system load' than the original one. If anyone else can have a look on this, cause I must say too, my computer is old and cheap, it may be different in another computer.
Skin FPS stills the same in both skins, as well as the other measures (audio, video).
geposted Fri 11 Jul 14 @ 6:58 am
I see no difference in cpu Running intel i5 however there was a slight increase in the ram used
geposted Fri 11 Jul 14 @ 7:22 am
I love the vumeters, they remind me my old equalizer ! I'm afraid I'll steal your design idea ^^
geposted Fri 11 Jul 14 @ 7:28 am
Thanks for testing friend ! :)
geposted Fri 11 Jul 14 @ 8:08 am
No problemo :)
geposted Fri 11 Jul 14 @ 8:09 am
v0.3b
- Some rhythmzone bugs addressed
geposted Sat 12 Jul 14 @ 5:39 am
Soon...
geposted Sun 20 Jul 14 @ 7:21 pm
Can you make the Album Covers Larger if Can
geposted Tue 22 Jul 14 @ 6:54 pm
geposted Tue 22 Jul 14 @ 8:26 pm
Looking good fruit , When do you think it'll be released
geposted Tue 22 Jul 14 @ 8:36 pm
ASAP my friend ^^
geposted Wed 23 Jul 14 @ 5:23 am
geposted Wed 23 Jul 14 @ 8:06 pm
Nice Nice Nice....mmmmmmmmm BiG FRUiT:-)
.....I might add a picture with my idea .... the chance 'to have a digital display .... what do you think Fruit??
geposted Thu 24 Jul 14 @ 4:48 am
Hmmmm, I wonder where you got those jog wheels from? LOL!
That's just a cut and paste image for demonstration, not actual coded skin - yes?
geposted Thu 24 Jul 14 @ 11:05 am
