A german user reported, that VDJ will close if you press the X button a 2nd time after being asked "a track is still playing....".
Happens too, if you do a double-click.
I can confirm that.
It should not close when the dialog box is open. Maybe it is a modal dialog?
I can confirm that.
geposted Sat 12 Jul 14 @ 2:55 am
I can also confirm this.
geposted Sat 12 Jul 14 @ 12:55 pm
same for me too
geposted Sun 13 Jul 14 @ 7:01 am
This behavior is the same as the load command, where using it a second time confirms the dialog so that the action can be used from controllers as well.
geposted Sun 13 Jul 14 @ 8:05 am
Why not two different options / behaviors ?
geposted Sun 13 Jul 14 @ 1:21 pm
Yes, two different behaviours would be better.
It's legit for the load dialog, but not for the close dialog.
geposted Mon 14 Jul 14 @ 8:11 am
