-Fix some OS X 10.10 issues
-Fix HID color output
-Improve HID digit output
-Fix beatphase detection bug
-Fix VST plugin parameters not remembered
-sampler_mode action can work on individual samples
-sampler_loop can toggle loop on/off
-Fix activating slicer or loop roll can cause drop-out for a short time
-Fix slicer sometimes not turning on or off
-Fix slicer when used inside loop
-fix sampler_mode for specific samples
-"None" option added for videoAudioOnlyVisualisation
-Small looproll fix
-fader start doesn't trigger loading of a new song
-slicer "step" fix
-effect_select_multi "video" +1 fixed
-fix loop roll position marker sometimes not disappearing
-slicer x "pressed" action to check difference between active slice and highlighted slice
-fix beatlock unable to pause/stop deck
-fix possible glitch when slicer button released
-fix possible crash when reading corrupt id3 tag
-Fix crash with some djc actions
-Fix visual type='color' on mac
-Filter folders using 'top' are automatically sorted now
-Reverb effect parameters shown as starting from 0 instead of from center
-Small looproll fix
-slicer "step" fix
geposted Sun 16 Nov 14 @ 7:45 am
OK, confirmed that using sampler_loop 1 switches sample 1 between loop and drop.
However, this can only be seen when using the sampler list view (where the mode heading can be displayed).
Can we please have a way of displaying loop/drop status somewhere? Either on the pads or elsewhere on a skin by using a get command perhaps?
When in list mode, we can change volume and length by clicking those areas. We also need ability change between loop & drop by clicking on it.
Also, please consider giving us back the ability to record directly to individual sample slots.
Thanks
geposted Sun 16 Nov 14 @ 8:25 am
Tried to update, the known loop message from earlier updates came back: "Update failed, do you want to try again?"
Checked the processes VirtualDJ.exe is still running and cannot be forced closed.
Windows 8.1
Windows 8.1
geposted Sun 16 Nov 14 @ 8:26 am
Some new loop problems: Smart loop not working and loop goes back by itself
try this:
1.turn on smart cue
2. turn on smart loop
3. load song and store a 8 beat loop and a hotcue at SAME place
start song and play stored loop.
1st bug:
press a button with stored loop --> Smart loop will not work!
2nd bug:
while the stored loop will play, press the hotcue button you have stored on the same place as the loop.
press 3-5x and look at the loop_in point on waveform. It goes back by itself. (see pic - bottom waveform)
3rd bug:
while the stored loop will play, press a empty hotcue button (emty slot) and jump to this Hotcue
The new hotcue set a new loop in point. This is imho not correct, too
try this:
1.turn on smart cue
1st bug:
2nd bug:
3rd bug:
geposted Sun 16 Nov 14 @ 9:38 am
sync didn´t work on big BPM difference, it goes the other way, rather than in + it goes in - and at - in +
geposted Sun 16 Nov 14 @ 10:38 am
Visual mp3 is disabled only when moving from one plate to the other, milkdrop not work archvios dragging on the right course ...
geposted Sun 16 Nov 14 @ 12:07 pm
DDj-SX 2 No audio on the Slicer light will light up,but if I go to the drop down slicer tab and hit 1then sound.b4 didn't had to hit tabs to turn on.
geposted Sun 16 Nov 14 @ 1:42 pm
Noticed this too. SX2 audio cuts off when slicer is selected, comes back on when a pad is pressed.
Keith
Keith
geposted Sun 16 Nov 14 @ 2:23 pm
same here
geposted Sun 16 Nov 14 @ 3:10 pm
For controllers with Slicer & Loop Roll Mode Pads, please check again with 2048.870
geposted Sun 16 Nov 14 @ 4:09 pm
djnice :o) wrote :
1st bug:
1st bug:
Smart Loop works here. What do you expect when Smart Loop is enabled ? Smart loop simply will trigger a loop at the nearest beat length if Loop In and Loop Out (manual loop) are used. The Smart Loop is not offering "Snap to beat" functionality.
And just in case you meant Smart CUe.. of course it wont work if you use the LOAD Loop button to trigger the Loop. Its not a hotcue point.
djnice :o) wrote :
2nd bug:
2nd bug:
Well, what it does here is that indeed the loop is a bit moved, but the Hotcue works as expected with Smart Cue (quantized) and if you leave the saved loop to go on, its still a seamless one. The graphic is indeed a bit confusing though.
djnice :o) wrote :
3rd bug:
3rd bug:
Setting LoopAutoMove ;)
geposted Sun 16 Nov 14 @ 4:33 pm
A bit confused here. An example please ?
geposted Sun 16 Nov 14 @ 4:40 pm
I think he's describing the nearest match auto bpm behaviour... if a track is 150pm and you match it with one at 80bpm, it'll go to 160bpm which is + instead of -
but imho mostly wanted behavior...
however, 1 improvement could be made.. when you increase the pitch on one of the tracks it should take that in account when matching, currently, it doesn't, it matches based on the stored bpm difference...
geposted Sun 16 Nov 14 @ 9:48 pm
@MrBlubke I'd second that. (sync based on current tempo not neutral tempo)
Although there are times I'd like to choose between absolute sync and the current sync
geposted Sun 16 Nov 14 @ 10:16 pm
it is enough a difference of 23 BPM and if you push sync you will see what happened
geposted Mon 17 Nov 14 @ 1:21 am
Using VDJ 2048.868 (version 2048.870 not updated yet)
When clicking on PFL button and turning it off there is no more sound on headphones. This happens 1st time with this new version.
Windows 8.1 OS, Controller VDJ ERGO V.
geposted Mon 17 Nov 14 @ 3:10 am
Pioneer DDJ ERGO V CROSSFADER between 2 decks doesn't work correctly with VDJ 2048.868.
geposted Mon 17 Nov 14 @ 3:40 am
From what I understand the first four digits of the version number is the build number, and the three digits after the '.' is the skin revision. Is it still true that skin changes don't come down with the auto update process?
geposted Mon 17 Nov 14 @ 1:13 pm
The numbers after the . are the controller database version. Skin changes are not included in the auto-update, no.
geposted Mon 17 Nov 14 @ 1:17 pm
hello, I just formatted and re-install my osx 10.7,tried the new build 2048,but my issues still happen: scratchwave drift, high cpu causing some stutter when loading tracks or analyzing, will VDJ8 Support work on some update fixes for OSX 10.7???? I see that this b2048 had fixes for osx 10.10
everything ran fine back in b1845, and b2003(except for some static) , since update 2013 that I'm having serious CPU issues, and I'm not the only one with motorized platter controller having issues, I've also had feedback from users in timecode setups with similar issues to mine, so I'm not an isolated case...
http://www.virtualdj.com/forums/195825/VirtualDJ_8_bug-report_Forum/No_Luv_For_Us_DJ_s_With__Spinning_Platters__I_m_Done_With_VDJ_8.html
http://www.virtualdj.com/forums/193591/VirtualDJ_8_bug-report_Forum/bad_static_when_scratching_slowly_.html
http://www.virtualdj.com/forums/187407/VirtualDJ_8_bug-report_Forum/CPU_usage_high_on_Mac_.html
http://www.virtualdj.com/forums/187474/VirtualDJ_8_bug-report_Forum/Terminal_Mix_4_Complete_Audio_Loss.html
http://www.virtualdj.com/forums/189832/VirtualDJ_8_bug-report_Forum/Constant_Skin_redrawing_eating_the_CPU.html
http://www.virtualdj.com/forums/187139/VirtualDJ_8_bug-report_Forum/Denon_3700s_x1600_issues.html
http://www.virtualdj.com/forums/194606/VirtualDJ_8_bug-report_Forum/Random_Audio_stutter____.html
http://www.virtualdj.com/forums/192941/VirtualDJ_8_bug-report_Forum/VDJ8_%28with_MacBook_Pro_and_NS7II%29_-_songs_changes_BPM_and_Key_by_itself.html
http://www.virtualdj.com/forums/187462/VirtualDJ_8_bug-report_Forum/Setup_motorWheelLockTime_cannot_be_set_to_0_0.html
http://www.virtualdj.com/forums/192191/VirtualDJ_8_bug-report_Forum/VDJ_8_keeps_crashing_and_restarting_every_45_mins.html
http://www.virtualdj.com/forums/188878/VirtualDJ_8_bug-report_Forum/numark_v7.html
please Atomix Supprt give us an answer, please.
(anyway will bootcamp my macbook for win7 will report some results later, but I really dislike using windows 7 on a mac machine)
thank you
thank you
geposted Tue 18 Nov 14 @ 6:55 am
