Topic: Lock Cue Points................. - Page: 1
Is this a bug,
I have to hit the padlock to lock my cue points for EVERY single track???
I figured if I hit the padlock it would lock basiclly every track I load but it seems this is not the case.
Is something wrong here??
geposted Mon 02 Feb 15 @ 10:19 am
Yes i agree - it should remain on when a track is reloaded.
Need an option in settings:
resetCueLockOnLoad - YES? NO?
Have reported.
geposted Mon 02 Feb 15 @ 1:59 pm
Awesome!! Thanks Dan, I thought I was going crazy because the lock wouldn't stay, lmao!!
@Bob if your reading this Dan answered my questions. It's not a bug.
Please can we get Dans idea implemented in a future update??
geposted Mon 02 Feb 15 @ 3:04 pm
I disagree. LockCues is a track specific action, and it should stay that way...
Basically the concept behind it is to lock the cue-points on tracks that you have set all the POI's as you want them and you want to protect them from being modified/deleted by accident.
I can't imagine why someone would want to lock the POI's on his entire library, especially since once locked, you cannot even set a new POI...
geposted Mon 02 Feb 15 @ 3:49 pm
What about the user that has all his cue points set exactly as they wish? No need to change them.
I'm not suggesting the current 'default' method should change. But having the option should be available for those who do not want to change cues inadvertently, and do not want to remember to press the lock button after each load.
geposted Mon 02 Feb 15 @ 3:59 pm
I would like the choice..........
If I need to make a change its as simple as clicking a button but I don't wanna click this button for EVERY single track, that's crazy plus that could take days if I keep at it.
I've rebuilt my libaray since 8 was first dropped, IF I had known I had to lock each track I would of (wouldn't of been happy about though). I'd just like to see the option, I mean it can't hurt anything can it??
geposted Mon 02 Feb 15 @ 4:09 pm
Just remember to unlock each time you load a new track :P
geposted Mon 02 Feb 15 @ 4:11 pm
Agreed.
geposted Mon 02 Feb 15 @ 4:50 pm
+1
I also think it would be better to have the choice over the default setting as beatbreaker said, as I think it would be easier/quicker to unlock a track to work on it rather than having to lock each track seperately.
geposted Tue 03 Feb 15 @ 3:46 am
You could do a Find and replace action on the database with a text editor.
geposted Tue 03 Feb 15 @ 7:25 am
+1 need a global CUE point lock (so you can use POI editor to set them and not risking deleting them in a live situation)
i ve never bothered with cue points because of this - too easily lost
geposted Tue 03 Feb 15 @ 9:01 am
I'm not sure how you could easily lose cue points though...
On most controllers some additional delete/long press/record button is required, and on the skin it's right-click.
If you frequently have that happen, don't you have problems with other buttons too (accidentally pressing stop during a mix for example?)
geposted Tue 03 Feb 15 @ 9:31 am
I'd just like a choice. Hit this ONE button for EVERY SINGLE TRACK is becoming a pain.
geposted Tue 03 Feb 15 @ 9:41 am
True, it's the machine's job to do simple repetitious tasks, not the user's.
geposted Tue 03 Feb 15 @ 9:54 am
Just advised breaker, I may as well share with everyone
Ok follow these instructions
1 back up your database
2 open your database with a text editor and press Ctrl+H, (AKA edit>find&replace or edit>replace)
3Find
<Infos
Replace with
<Infos LockedCues="1"
Replace all
4 Save
That's it
geposted Tue 03 Feb 15 @ 10:45 am
Loco for the win!!
Thanks bro for the info!! I think Atomix is gonna stick this out kinda like the stupid glare on the Rythum wave but unlike that at least we have work around!
Thanks again! 👌
geposted Tue 03 Feb 15 @ 11:09 am
+1
geposted Tue 03 Feb 15 @ 11:38 am
a right click is easily done sometimes ;-)
geposted Tue 03 Feb 15 @ 5:14 pm
Confirmed Locos fix works perfectly!!
Thanks again bro!
Now Im just awaiting my skin from Bob with the lock cues button added.
geposted Tue 03 Feb 15 @ 5:32 pm
Which skin do you use? You could have it on a custom.
The script is
lock_cues
geposted Tue 03 Feb 15 @ 5:53 pm
87%
