-Slicer 'hold' mode fix
-Fix for using multiple video effects on master with certain effect combinations
-fix regression bug caused by skin cover mask
-add 'mov' file support to slideshow plugin
-Fix edit_singer locking up video and skin while entering name
-Bitrate for vbr mp3's corrected during batch analyze
-New setting 'hotcueMode' with options for play and stutter when playback stopped
-Change hot_cue stutter mode to use stutterCue
-Fix param_multiply not working in some cases
-Fix regression bug with get_browsed_song
-Relocate function automatically reloads song on deck
-param_cast option added to format numbers with a specific number of digits
-touchwheel backspin/forwardspin not triggered at very low speeds
-browser_enter fix for moving to the next subfolder of an empty folder
-browser_options menu improved for touch screens
-fix sampler actions when specifying sample by name
geposted Sun 08 Mar 15 @ 7:19 pm
geposted Sun 08 Mar 15 @ 8:00 pm
Hi guys,
I think I just had some crashes, am online.
Automix/remove intro outro/8 seconds, the songs (mp3) don't load on to the decks!
if I turn AM off, they load and play fine.
Thx
Thx
geposted Mon 09 Mar 15 @ 8:27 am
Bypass that green band by zooming in. not a fix but a temporary solution..
geposted Mon 09 Mar 15 @ 8:28 am
first time I got a crash in 3 months.
geposted Mon 09 Mar 15 @ 10:55 am
No crash report on your account, were you online at the time? If not, any chance you can try and replicate whilst you are?
geposted Mon 09 Mar 15 @ 11:19 am
I like all of these words, but I'm left guessing, Is it skins, controllers?
geposted Mon 09 Mar 15 @ 1:21 pm
for both. Not sure what is implemented (besides text), but one thing working for sure is ..
param_cast 'text' x
which provides the first x characters of the calling value/string starting from left.
param_cast 'text' x
geposted Mon 09 Mar 15 @ 6:54 pm
Not sure what this was supposed to do but its a whole lot worse now. I won't even use this beta!!
And making me push the platter forward on a CDJ is the wrong thing to do, you don't know how look it took me to break myself of that when using CDJ's.
geposted Mon 09 Mar 15 @ 7:22 pm
Switch to video (milkdrop as audio only) via custom button but cannot turn off video via the same button.
geposted Mon 09 Mar 15 @ 10:09 pm
Look what happens if you load the same song in both decks
geposted Mon 09 Mar 15 @ 11:01 pm
He probably did not notice but it also happens to him...
raypitman wrote :
Hi guys,
Thx
Thx
geposted Mon 09 Mar 15 @ 11:24 pm
@ djswid
no, I didn't have the same songs loaded on both decks, my pic was while using a playlist in AM
geposted Tue 10 Mar 15 @ 2:11 am
no, I always put off my wifi when I use VDJ. I'll put it on and play the same playlist again. But I did nothing special. It just stopped and I got the long rapport. Maybe it is saved automaticly somewhere on my laptop? I use a macbook Pro. As controller 2x cdj850, DJM800 via USB/midi, only videofader and a novation launchpad.
geposted Tue 10 Mar 15 @ 2:27 am
I get a crash when doing this :(
geposted Tue 10 Mar 15 @ 3:45 am
me too!
geposted Tue 10 Mar 15 @ 4:50 am
same here..... using w8.1, i7, 8gb ram, nvidia 650m.
geposted Tue 10 Mar 15 @ 5:53 am
+1 on w7 32b, Core(TM)2 Duo E7500 @ 2,93GHz
There is a similar bug when cloning decks. The software doesn't crash but the song stops preloading.
geposted Tue 10 Mar 15 @ 5:58 am
This has been acknowledged in another post somewhere. Should be fixed next build.
Here:
https://virtualdj.com/forums/199136/VirtualDJ_8_bug-report_Forum/4_bugs_on_the_latest_version_of_vdj8.html
Here:
user8689935 wrote :
BUG1: When I load a song in deck2 which is the same song already loaded on deck 1 the waveform on the top disappears for some reason. it even does it when i press clone deck on the scratch mode
Adion wrote :
1. Will be fixed next build
geposted Tue 10 Mar 15 @ 6:20 am
Just tried loading same track to both decks here.......and no problem.
Windows 7 Home Premium 32 bit SP1
Intel Core2 Quad Q6600 2.4GHz
[EDIT] Oh, it's the rhythmwave! I thought it was an issue with the songpos wave. They look very flat in those pics.
geposted Tue 10 Mar 15 @ 6:25 am
