But did you try to load both while the first is still preloading ?
geposted Tue 10 Mar 15 @ 6:34 am
No, I don't do that. It's not good practice.
[tries the bad habit] Yes, if I do that the songpos is flat and VDJ crashes.
Solution = don't do that! :-)
geposted Tue 10 Mar 15 @ 6:37 am
Me either, I just did it to confirm the crash :)
geposted Tue 10 Mar 15 @ 6:41 am
I'm still getting the bug with 2171 :
Also, there's now a strange behavior when switching :
- menu deck / wheel / art
The cover is not showing correctly (it is supposed to show over the songpos ring).
Note: The mask problem happened only once. After relaunching the software I can't seem to be able to repoduce. But stills, the option I described is bugging now (it shows some artifacts all along the songpos ring and the words now appear in red instead of white (when there's no cover to show). The cover picture is 'red-ified' too, on both decks).
geposted Tue 10 Mar 15 @ 7:30 am
Hi Fruit,
The clipmasks for your rotating covers are currently transparent with coloured circles; they should be black/white masks :)
Regards,
Scott
Regards,
Scott
geposted Tue 10 Mar 15 @ 9:16 am
Mm, actually it's a feature, to shade some parts of the cover (for the 'art' option mainly).
geposted Tue 10 Mar 15 @ 11:01 am
PachN wrote :
Same with some some..OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
DJ SWID wrote :
Look what happens if you load the same song in both decks
geposted Tue 10 Mar 15 @ 2:50 pm
you dont have to quote the same posts. Bug is spotted from the Dev Team and probably fixed for the next build.
geposted Tue 10 Mar 15 @ 2:52 pm
