Changes "GianB 4 Decks v3.2":
- Top Wave: Add a button "G" (Grid), to enable/disable grid view for Scratch Wave
- Deck: Add a button "U" (Undo), to undo the loaded track to previous loaded track
- Deck: Add a button "Video" (under main select deck), to enable/disable bigger video/cover view on deck
- Deck: Add Right-Click on number of active Deck Effects, to disable all Deck active effects once
- Deck: On BPM value, add Right-Click to Reanalyze BPM
- Mixer Section (4 Decks view): Add Master Balance Knob
- Mixer Section (2 Decks view): Add Master Volume and Master Balance Knob
- Video Section: Add "Master" button to enable/disable the view of only Master video output
- Video Section: Removed 2 Custom Knobs
- Video Section: Add 6 Custom Buttons (12 total)
- Video Section: Optimized Video Section on 2 Decks view, such as 4 Decks view
- Master Section (4 Decks view): Add the view of number of active Master Effects. Right-Click on it disable all active effects once
- Master Section (4 Decks view): Replaced 12 Master Effects Knobs with 14 Master Effects Slider
- Master Section (4 Decks view): Add 14 Master Effects buttons under Master Effects Sliders (visibile only if the button is active)
- Master Section (2 Decks view): Removed Broadcast panel
- Master Section (2 Decks view): Replaced 1 Master Effects Knobs with 7 Master Effects Slider
- Master Section (2 Decks view): Add 7 Master Effects buttons under Master Effects Sliders (visibile only if the button is active)
- Master Section: Add text visual Controller Name
- Some other minor fixes
geposted Sun 04 Oct 15 @ 10:25 am
Wow ... good work ... thank you
Would it be possible to add the possibility to disable the custom buttom?
I have some more remarks / questions / wishes, but i think it would be better to send you an pm :-)
Lokke
Lokke
geposted Mon 05 Oct 15 @ 7:27 pm
Grazie per il tuo lavoro, è la mia skin preferita.
geposted Thu 08 Oct 15 @ 7:25 pm
I want to use the skin in 2-deck view, but still have a third deck hidden, as I will assign the sampler to.
I don't want to go for the 4-deck view, the browser will be so small.
Could you please tell me where in the XML file I change from 2 decks to 3 ?
I hope you understand what i was trying to tell.
Summary: I want the 2-deck skin to handle 3 decks, and the 3rd deck will only be assigned the sampler so I can use deck FX separately on the sampler.
geposted Thu 15 Oct 15 @ 6:25 pm
I MrJackson2014,
I don't understand clearly what do you mean.
I only know that it's not simple to change this skin from 2-4 to 2-3: there are many xml code to rewrite completly and change graphics file resource too.
geposted Thu 15 Oct 15 @ 8:41 pm
I'm so sorry for explaining bad.
I'm using your skin in 2-deck mode, and I must say it's totally brilliant. GOOD WORK!
As I am using the sampler a lot I want to add FX to it. That's where the 3rd deck comes in.
I assign the sampler to output at deck 3, just to be able to add audio FX.
I really don't need to see anything related to deck 3, just to be able to route sampler output to it.
This evening I figured out, in your skin, decks 3 and 4 are available even in 2-deck mode, so problem is actually solved by itself. :)
geposted Fri 16 Oct 15 @ 6:29 am
Ok, now it's clearly.
I'm pleasure you like this skin and solve your necessity with it.
Best Regards
Best Regards
geposted Fri 16 Oct 15 @ 7:13 am
Any plans to make a daylight version ?
geposted Tue 20 Oct 15 @ 5:49 am
I'm sorry, but for daylight version I think no plans from now.
geposted Tue 20 Oct 15 @ 6:27 am
Changes "GianB 4 Decks v3.3":
- Add Options to Show/Hide some components:
. Decks Custom Buttons
. Video Custom Buttons
. Master Custom Buttons
. Decks Beat Bars
. Decks Beat Counters
. Clock
. Power Icons
. CPU usage
. Sampler Button
. Top Sampler Bank
. SandBox
. Audio Cross Fader
. Buttons Audio Cross Fader
. Video Cross Fader
. Buttons Video Cross Fader
- Some minor changes
. Decks Beat Bars
. Clock
. Power Icons
. CPU usage
. Sampler Button
. Top Sampler Bank
. SandBox
. Audio Cross Fader
. Video Cross Fader
geposted Wed 04 Nov 15 @ 1:03 pm
nice update, think i found a bug.. the fader only work in mixer mod, not in video mod
geposted Wed 04 Nov 15 @ 4:22 pm
the crossfader in the skin work i mixermod but not in videomod
geposted Wed 04 Nov 15 @ 5:32 pm
Excuse me, but I don't understand the problem: the fader in Mixer/Scratch/Master section it's an audio cross fader; the fader in Video section it's a video cross fader, so it's not the same funciontality. What's wrong ?
geposted Thu 05 Nov 15 @ 7:47 am
Ok i did not know that there where different functions on the crossfaders
geposted Thu 05 Nov 15 @ 11:47 am
. Decks Beat Bars
. Clock
. Power Icons
. CPU usage
. Sampler Button
. Top Sampler Bank
. SandBox
. Audio Cross Fader
. Video Cross Fader
. Decks Beat Bars
. Clock
. Power Icons
. CPU usage
. Sampler Button
. Top Sampler Bank
. SandBox
. Audio Cross Fader
. Video Cross Fader
TOP ... i like it ... very good Job!
geposted Mon 16 Nov 15 @ 8:27 pm
Changes "GianB 4 Decks v3.4":
- On Top: Merge 3 Wave menu buttons options, to one Wave menu button options
- On Top: Add Video Transition selection
- On Top: Add 2 Custom Buttons
- Add Options to Show/Hide components:
. Top Custom Buttons
. Top Video Transition
. Button En./Dis. Audio Cross Fader
- Add small button to Enable/Disable Audio Cross Fader
Happy New Year !
Happy New Year !
geposted Wed 30 Dec 15 @ 1:55 pm
Ciao GianVJ
uso la tua skin principalmente a 2 deck
usandola per un servizio in cui avevo bisogno dei 4 deck mi sono accorto
che quando dalla mia pioneer sx2 davo il comando di passare dal deck 2 al 4 la numerazione che indica il deck attivo sulla skin non cambiava e mi indicava in tutte e due i deck il 2, idem da 1 a 3
puoi controllare?
grazie
puoi controllare?
grazie
geposted Mon 18 Jan 16 @ 3:30 pm
Ho controllato e hai ragione ErikVeejay.
Ho già mandato la correzione allo staff di VirtualDJ.
Grazie per la segnalazione.
geposted Tue 19 Jan 16 @ 7:47 am
geposted Tue 19 Jan 16 @ 8:26 am
Changes "GianB 4 Decks v3.5":
- Fix label number of Select button on Deck "3" & "4" (was erroneously "1" & "2")
- Some minor graphics changes
geposted Thu 21 Jan 16 @ 7:45 am
