Localization of default skin find a serious error,
After some fields translation,Unable to display other language translation;
For example:
For example:
geposted Thu 15 Oct 15 @ 12:52 pm
I don't understand what you mean exactly.
If you have a translation xml that is broken, could you send it to me?
(Also, it is recommended to remove the update="" fields from the xml after updating the translation, that way it will be much easier to update the translation in a next version, since only the items that require an update will have a new update="" field)
geposted Thu 15 Oct 15 @ 1:00 pm
My friend Adion,I translated it again,Everything is all right,I don't know where is the problem.
I feel...After translation, only show two words,And very small.On the low resolution does not make sense.
But in terms of language localization,this is a very good job.
There have been a few other products do well in Chinese,Including the official website,I have been working to promote the VirtualDJ.
1920x1080
geposted Thu 15 Oct 15 @ 1:35 pm
Can you send the updated translation? It looks good, although some words indeed look very small.
geposted Thu 15 Oct 15 @ 1:52 pm
Full unexpectedly close while working ...
geposted Sat 17 Oct 15 @ 6:55 am
Details?
geposted Sat 17 Oct 15 @ 10:55 am
system completely frozen (video& audio), because lost sound card (controller)
after re-pressing "Apply" all operate normally
system w7/64bit
vestax vci 380
system w7/64bit
vestax vci 380
geposted Sat 17 Oct 15 @ 11:58 am
The sound effects on deck stop working until I close virtual dj and open again, then happened again last night, also I still cant figure why I can only see the color text tags in the browser and remove samplers only if I run vdj as an administrator to open it.
geposted Sat 17 Oct 15 @ 10:06 pm
http://es.virtualdj.com/forums/204670/VirtualDJ_Plugins/Clipbank_and_TellyMedia.html
Adion where I can find the crash report to submit ????
geposted Sun 18 Oct 15 @ 4:32 am
You can't. If you are online while the crash happens the crash report is submitted automatically.
Also, the screenshot in that topic looks like it's a lock-up, not a crash, so unfortunately there would not be a report anyway.
geposted Sun 18 Oct 15 @ 5:07 am
if it was an accident ...... you can not capture the closure warning sign program
that precious must crash report on options virtual dj ??
geposted Sun 18 Oct 15 @ 5:30 am
my options
It is correct???
It is correct???
geposted Sun 18 Oct 15 @ 6:11 am
Pin a Effect on the window and can't turn on or off from @ the pin window and can't remove it also need to close VDj-8 to remove it.
OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Sun 18 Oct 15 @ 5:58 pm
