Forum: Addons
Addons comments
Topic: SilverSleek 3 - Page: 1
Discussion about SilverSleek 3
Updates log:
2016-06-06 v3.1
Initial release
2016-06-07 v3.2
Fixed a bug on "4Decks in Line" view where Rhythm section was showing only 2 deck waveforms.
Fixed a bug on "4Decks in Line" view where drag & drop was loading only deck 1 or 2
2016-06-09 v3.3
Added new central panel "Scratch Video" on 4 Decks Swap view.
2016-06-21 v3.4
Added new central panel "Video Full"
geposted Mon 06 Jun 16 @ 3:43 pm
mankanPRO InfinityMember since 2012
Hi!
Nice update of the skin!
I see that you have add a "Freestyler controller" in the Top Bar menu. Is it possible to even add "The lighting controller" for Showxpress?
geposted Mon 06 Jun 16 @ 6:16 pm
I will check the plug-in and see...
geposted Mon 06 Jun 16 @ 6:17 pm
When the central panel is showing the sideview, if I select the sampler in the main browser sideview tab, then change the sampler view between pads and list, the central panel does not switch, it only shows the list view of samples. Is this a bug?
geposted Mon 06 Jun 16 @ 6:42 pm
It's a limitation of the sideview element whaen used for skins / custom browsers. The same way that "Sampler" view for central panel always shows the pads view and not list view
geposted Mon 06 Jun 16 @ 9:02 pm
Hola lo quise instalar pero no me lo ha instalado que ocurrira? tengo la version 1 y 2! gracias espero tu respuesta
geposted Mon 06 Jun 16 @ 10:12 pm
Si usted no tiene VirtualDJ 8.2 en su sistema sin embargo a continuación algunos elementos de la piel no funcionarán. Así que es mejor esperar hasta que upfate a VirtualDJ 8.2. También SilverSleek3 no pretende sustituir o SilverSleek2. Es una nueva piel
geposted Mon 06 Jun 16 @ 10:21 pm
V3.2 Out!
geposted Tue 07 Jun 16 @ 9:42 am
dcomoPRO InfinityMember since 2012
Awesome skin!!!! Continue to do amazing things!
geposted Tue 07 Jun 16 @ 8:45 pm
Hi PhantomDeejay
I love your skin and use it for most of my DJ'ing but find your default Main video size too small i know this is a BIG ask but was wondering is you could make a center panel that looked more like this
sorry this is just copy and pasted together. i know this cheeky from me asking like this and hope you're not offended by it
Thank you for your time and effort you put into your skin it is amazing
P.S Will we be seeing a return of the Phantom Layout
geposted Thu 09 Jun 16 @ 8:36 am
V3.3 Out!
geposted Thu 09 Jun 16 @ 10:58 am
Just added this view:
geposted Thu 09 Jun 16 @ 11:00 am
OMG Thank you
geposted Thu 09 Jun 16 @ 12:08 pm
How do you access that view?
geposted Sat 11 Jun 16 @ 11:24 am
it is under central panel in the 4 deck layout
geposted Sat 11 Jun 16 @ 11:53 am
lastimosamente creo que no me sirvio esta vercion en especial los fx en decks le doy a layout y solo me aparece 2 decs ni compact ni ecential y pues no puedo elegir ni los fx ni tampoco puedo usar los pads en controller elegia sz aunque lo que uso es una torqxponent y me funcionaba muy bien en la 2 pero en esta no puedo ni pasar a los cue o roll slicer o sampler si me pudieran ayudar con esto estaria muy agradecido saludos!
P.D. y en el centro de los browser bottons me quitaron el max browser y pusieron el relay que por cierto no se ni que chingados es eso =D
geposted Mon 20 Jun 16 @ 5:22 am
Estimado buenas tardes tengo dos consultas
1. Como activo el pitch lock para poder usarlo y descativarlo porque a veces los pitch del canal 1 y 3 se mueven iguales y no se porque pasa eso, uso un controlador pioneer sx 2
2. A veces me da problemas de la funcion filter se descativa y no hay como avtiarlo nuevamente y no se a que se debe eso.
geposted Mon 20 Jun 16 @ 9:50 pm
V3.4 Out!
geposted Tue 21 Jun 16 @ 11:19 am
Esta piel es para la versión 8.2. Es por eso que las almohadillas no funcionan correctamente. También navegador de zoom se ha convertido en un botón en la parte inferior izquierda del propio navegador
geposted Tue 21 Jun 16 @ 11:23 am
This is my favorite skin, can you add the beat counter to the top bar? how to add a logo to the jog wheel?
geposted Tue 21 Jun 16 @ 4:40 pm
Seite : [>] [>>]
24%
