Each changable element in a skin is a skin panel, skin panels are controlled by variables, figure out what variables are attributable to which panel via the 'var_list' script, after that write a script to set the variables.
geposted Thu 18 Aug 16 @ 1:13 pm
Tried to add a custom logo and rezip the file but It won't work.
geposted Thu 15 Sep 16 @ 7:18 pm
More detailed info required. What were your exact steps, and PC or Mac?
geposted Thu 15 Sep 16 @ 7:38 pm
geposted Thu 15 Sep 16 @ 7:47 pm
geposted Thu 15 Sep 16 @ 7:50 pm
So you've created a new file called SilverSleek3DEV.png?
That won't work, because the XML code references the original png file name. Adding a new one with a different name will not allow the XML file to see/use it.
You need to save your changed png with the same name as the original (overwrite it).
geposted Thu 15 Sep 16 @ 8:03 pm
Thank you. So I can't send it to someone to edit and they send it back to me like I did. I have to do it on this same computer?
geposted Thu 15 Sep 16 @ 9:35 pm
Wrote over the original file and now how do I get the software to recognize it?
geposted Thu 15 Sep 16 @ 9:47 pm
You should recompress the SilverSleek3 folder to a zip file.
Right now on your skins folder you have a "SilverSleek3.zip" file which is the original skin and what VirtualDj sees, and a folder named SilverSleek3 with the new contents. That folder is not read by VirtualDj.
Rename "SilverSleek3.zip" file to "SilverSleek3_Original.zip" and then compress the contents of the "SilverSleek3" folder to a new zip file.
Don't compress the folder itself. Compress it's contents.
Then move the compressed file inside the skins folder and you should be able to select it from within VirtualDj
geposted Mon 19 Sep 16 @ 12:25 pm
....or you could just take the newly modified PNG file and drop it onto the original ZIP - this should then replace the original PNG file with the new one.
At least that's how it works on Windows :-)
geposted Mon 19 Sep 16 @ 5:43 pm
I got it thanks guys
geposted Wed 21 Sep 16 @ 5:33 pm
Is there a way to activate the beatcounter like you have with the v2?
I see someone asking a couple times already.
Thanks.. LJ
Thanks.. LJ
geposted Thu 06 Oct 16 @ 7:18 pm
Hi!
I am using this skin I and would like to know if there is any possibility to remove gridlines (whaen I talk about gridlines I mean the dots on the bpm).
Thanks!
Thanks!
geposted Thu 08 Dec 16 @ 12:57 pm
not lines then, you mean the grid markers
search the xml for entries that start
<grid
delete everything in that entry, the start and the end.
<grid ..stuff... </grid>
some waves may finish
<grid....stuff..../>
<grid
geposted Thu 08 Dec 16 @ 5:01 pm
How can I add a visual cue for sandbox mode as in the original skin
geposted Thu 05 Jan 17 @ 4:34 pm
beat counter?
geposted Thu 23 Feb 17 @ 10:32 pm
The master VU meter is unadjustabe with the master knob with or without gain.
I can't tell if my recording is too loud or not.
geposted Sun 19 Mar 17 @ 3:18 pm
this skin is awesome.
please add that [16 beat counter] for 4 decks. there's plenty of room.
keep up the great work.
geposted Sat 10 Jun 17 @ 6:40 pm
Hi,
I d/loaded silver sleek yesterday! It's nice!
So far things that are missing for me:
1) Beat counter range (on top)
2) How do I record?!?
Wonder if anyone can help me on this! Thanks!
geposted Sat 17 Jun 17 @ 3:02 pm
really good skin.. The best there is. However 3 isues:
1.) not clear when Master Tempo is on auto or not (Like in Fruit skin for example, it has a clear visual distinction) and even when mastertempo is NOT auto, right clicking master tempo shows RC: AUTO which is incorrect I think
2) no possibility to adjust sampler level. There could be room in this region. And vu meters would be nice on this view as well ;-)
3) Horizontal stripes would be really cool as an option.
This skin rocks though. Best I've come accross! Thanks for all your work
geposted Wed 21 Jun 17 @ 11:25 pm
