Forum: Addons
Addons comments
Topic: Browser Tweaks - Page: 2
leneerPRO InfinityModeratorMember since 2014
It doesn't work very well.Maybe there's something wrong with the encoding.
geposted Thu 03 Aug 17 @ 4:00 pm
lincol2PRO InfinityMember since 2011
I get a error message when I try to add color on Fruit skin, but the default skin works ok as pic ..
This tweek only works with the default skin?
geposted Thu 03 Aug 17 @ 4:47 pm
The Fruit skin is having the browsers as <define> elements, and Browser Tweaks cant handle those at the moment.
I could probably add this in a future update, but having second thoughts about it. If a skinner has chosen to have a variety of browsers as defines, then probably he has set some special colors/parameters for each (or else it wouldnt make sense to go that way), so applying the same browser tweaks to all browsers, could lead to unwanted results.
geposted Thu 03 Aug 17 @ 4:52 pm
leneer, what is the original skin you were trying to modify ? Is it one with a Chinese translation or a original one and which ?
did you choose any specific Font in the "Change the global skin font" ?
Help me to help you :)
geposted Thu 03 Aug 17 @ 4:54 pm
Yes,I changed the global skin font(Chinese Font);maybe only the default skin can be tweak.It should be a text/xml encoding problem.
geposted Fri 04 Aug 17 @ 8:08 am
geposted Fri 04 Aug 17 @ 8:10 am
Browser Tweaks has been updated to ver 3.1
Changelog:
- Browser -> Plugin -> Knob Ring Fill is now supported (requires VirtualDJ Build 3856 or later)
- Fix when skin uses <browserinfo>
- Fix when skin uses image="" without file extension
geposted Sat 02 Sep 17 @ 11:00 pm
Hi djdad - when installing Browser Tweaks, my AV (Avast) gave a positive for an infection. Querying this on the VDJ Facebook page, I was assured that it was a false positive; I installed it on that advice and it seems to work 100%.
It was suggested I notify you to perhaps tweak the code to alter the fingerprint slightly so this doesn't happen.
Picture attached.
geposted Sat 09 Sep 17 @ 7:27 pm
Can't do anything about it. Some Antivirus apps faulty detect almost all of our Addons are threads, but they are 100% safe to download and use (we check those before approving)
geposted Sun 10 Sep 17 @ 9:15 am
Seite : [<<] [<]
