Forum: Addons
Topic: Skin Builder - Page: 3
Are you not going to make the browser background transparent?
Could someone make a NEW skin for VDJ 8.2?
What do you mean? Someone could make new skins all day long with the Skin Builder.
I've posted this on the other thread about this utility but not sure that was the best place to put it so I'm copying it here as this thread seems to be more active...
Fantastic utility. Thanks a lot for developing it. I was really hoping something like this would become possible!
One question - Is there any way of separating out the 'deck options' so that there are individual markers/buttons for the options such as master tempo/smart loop/Quantize Loop/Smart Cue etc as was the case on some older skins and VDJ7 rather than the rather cryptic circle of on/off lights which I have never found very useful...
If it is not possible now any chance of it being added?
Cheers
Noted. Will add to next update. Dont ask when :)
Brilliant, thanks.
I'm biting my tongue keeping the 'when' word in! :-)
Krissmoller wrote :
Even more far out :-D
Thanks djDad for this tool, great stuff :-)
Kriss
I am having problems getting the browser to go full screen.
Can you help me out here
What resolution did you create your skin at, and what resolution if different do you have your screen at when yo use it
Thanks
Al
Kriss
Thanks
Al
Never mind, I was finely able to stretch the browser, I was not grabbing the bottom right corner correctly
Bob I wonder if you'd mind making a small change to the way the XML is generated?
I've been using the Builder skin to help with construction of my own skin. It makes things quicker if you can generate blocks of code for E.G. pads, without needing to write from scratch.
When I added some "Build generated" code to my skin, everything was in the wrong position. I later noticed that your code has the y= before the x= when most skin code I've seen is written the other way (x first).
Would it be possible to swap them around please?
Can you provide an example of a Skin Builder element where y is before x ?
The skin I extracted had just 3 standard FX sections and the pads.
It was just under 2000 lines of code, and as far as I can see, every co-ordinate is listed y x not x y.
Here's a few lines
<button action="effect_active">
<pos y="186" x="60"/>
<size width="70" height="15"/>
<selected y="900" x="3"/>
<down y="900" x="3"/>
<over y="885" x="3"/>
<up y="870" x="3"/>
<text width="67" color="#ffffff" align="center" size="8" dx="1" action="get effect_name" scroll="yes"/>
</button>
<button action="effect_select">
<pos y="186" x="129"/>
<size width="13" height="15"/>
<down y="900" x="72"/>
<over y="885" x="72"/>
<up y="870" x="72"/>
</button>
[later] I just checked a skin that I generated from your addon back in April. That's y before x too.
ah i see, ok will check.
EDIT. Fix will be available in next update.
BTW, regarding a couple of requests for missing/new modules.. An update along with a new utility is in works. With the new additions, you will be able to create your own modules (floating windows) and attach those to the current Skin Builder. Will inform you with further details once i finalize the project.
Here is a sneak preview ...
Excellent!
Hi there.
Would it be possible to have an "analogue" Clock in the Skin Builder?
Will there be a Skin Builder 4?
How were you able to add your pic to the background? I've played around in skin builder and in the extractor to try and find a way to add my own pic to the back ground
I am trying to use the skin builder but when the screen comes up I have no words showing for buttons on the top. When I open the box to add elements most of the checkboxes show no labels. Could this be a screen resolution thing, and can anyone tell me how to fix it? I am using VJ8.
It could be - but you haven't said what your screen resolution is...
@djdad, i have a skin im happy with but there are things missing i would like added. Can you help me?
Depends on what those are. Can you post a list here ?
73%
