Discussion about Numark Mixtrack Platinum Fix
geposted Mon 03 Jul 17 @ 11:45 am
Hi, I downloaded it and installed it, but nothing changes: I have always humm noise and the LEDs are always dimmed.
What do I have to do after the installation? I see this new file : ''Force Numark mixtrack platinum'' in the Devices folder. How can I use it?
Thank's for your help, Best regards, Christian
geposted Wed 12 Jul 17 @ 8:15 pm
I have a virtualDJ plus license. Should I have a virtual DJ pro license for use custom devices files?
With SeratoDJ I have almost no humm noise, but inactive leds cue/loop pads are off.
geposted Sun 16 Jul 17 @ 9:23 am
Makes sense that when the leds are off there is no humm. As I understand it, it's a bug in the firmware of the unit that the leds cause humm
geposted Sun 16 Jul 17 @ 6:24 pm
Yes exactly, or may be hardware: the power supply of the controller not well filtered
geposted Sun 16 Jul 17 @ 7:44 pm
Yes exactly, or may be hardware: the power supply of the controller not well filtered .. SeratoDJ use less dimmed LEDs. Normally this addon fixes this problem using less dimmed leds, but I can't found the way to use this addon.At this time I use the audio card of the PC: no humm, but I would prefer to use the audio card of the controller ...
geposted Sun 16 Jul 17 @ 8:23 pm
At this time Numark recognized this problem as a hardware fault. It can be repaired under warranty by sending it to their service center.
geposted Fri 08 Sep 17 @ 4:09 pm
That's good news. and thank you for sharing this info.
Kudos to Numark - despite the delay - for acknowledging the problem and offering a solution.
geposted Sat 09 Sep 17 @ 5:33 am
This fix works great , the annoing noise disapear, thanks a lot for this, i preffer Vdj than serato lite :)
geposted Wed 30 Jan 19 @ 10:14 am
ich habe den mixreax platinum fx gedownloaded und ich habe virtual dj pro aber er wird mir nirgends angezeigt bitte helfen sie mir
[script][/script]
[script][/script]
geposted Tue 27 May 25 @ 2:56 pm
You need to post in English here (or use the German area).
Did you not read the description? This download will not be "displayed anywhere" because it's a fix for a hum problem - as stated in the description.
Fixes the humm noise due to dimmed LEDs
geposted Tue 27 May 25 @ 4:53 pm
