Forum: Addons
Topic: Numark Party Mix Pro
geposted Tue 19 Sep 17 @ 2:33 pm
The pad mode switching does not work. I cannot switch from Cue to Loop to Sample etc.
This skin is meant to work with the default mapping of the PartMix Pro, so Pad modes are set only from the Hardware (and the skin follows)
Are you using it with a PartyMix Pro ?
No. I do not have a physical controller. I guess that answers my question.
Bonjour
J ai un party mix pro depuis Décembre 2019 et mon ordinateur ne le reconnait pas avec la prise USB.
Je ne peux donc pas m en servir.
Pouvez vous m aider?
Merci d avance
Is there/will there be a skin for Numbark Mixtrack Plaltinum
There are no dedicated controller skins any more.
