Topic: LE differences?
Hi,
Can someone please explain the difference between VDJ8 LE and the rest, as per the comparison page?
I was going to upload a snip of the page but it seems that is not supported here?
Specifically, I see LE has not got some of the library functionality.
Thanks.
geposted Thu 26 Oct 17 @ 11:31 pm
geposted Thu 26 Oct 17 @ 11:43 pm
Yep seen that, that's the page I was refering to in the above post, the question remains the same.
Let me ask a different way.
What library functions differ in LE to the other versions?
geposted Fri 27 Oct 17 @ 1:57 am
Depends which version of LE (how old the controller is as some still have V7) however I believe all LE versions of VDJ8 have track search disabled.
This has been debated for a long time and customers have bought a controller and been surprised about it but it still stands. Personally I would avoid LE purely for that reason as it renders the whole program useless in my opinion (and ultimately forces users to upgrade to Pro anyway). There is also no Automix functionality in LE.
As stated in another thread, it would probably be best to get a cheaper controller to start with (something like the Pioneer SB2) and just buy VDJ Pro outright.
https://www.virtualdj.com/forums/218107/General_Discussion/LE_version_features_and_limitations.html
https://de.virtualdj.com/forums/201103/Hardware_Technical_Support/Difference_between_Virtual_DJ_Pro_and_LE_.html
geposted Fri 27 Oct 17 @ 2:08 am
Thanks Mate:)
geposted Fri 27 Oct 17 @ 3:16 am
