Forum: Addons
Topic: Minimalist UX 3
geposted Fri 08 Jun 18 @ 10:16 pm
Hi .. please How To Use this Video Skins ?
Help me
In VDJ 8.3 (aka Virtual DJ 2018).......
Open the VDJ config window and select the tab for changing skins. The video skins are listed below the main skins.
i also cannot find out how to use this, there is no tab in the settings for me to select this skin, i am using version 8.2 and do not see the video skins listed under the normal skins
Get the recent update.
is there no way to use them on 8.2?
Correct
I love this Interface, but, can there be a version without the analyser?, just showing the song title? as I want to run advertising in the background,
Thanks.
Hey quick question...is there a way to move the text and spectrum to another area of the screen as well as resizing it? I video stream online and have various scenes where the text and spectrum sections need to be moved and/or resized. I would like toalter the XML file for the skin and rename it so I have different versions of the same skin.
Is there an xml manual for making changes and if so where do I find it?
You can change it easily yes, its not that many xml elements in the skin...
Size and position are easily read from the xml
https://www.virtualdj.com/wiki/Modify%20a%20Skin.html
