Discussion about Title GFX 1
geposted Wed 11 Jul 18 @ 12:06 pm
Amazing work. Thank you very very much!!!
geposted Wed 11 Jul 18 @ 12:28 pm
Hi dj-in-norway
I have a question. How can I delete it white circle on the coverart?
Thank you for your response.
geposted Wed 11 Jul 18 @ 12:58 pm
It's okay now. I gave it a black color :)
geposted Wed 11 Jul 18 @ 1:37 pm
VJ Python wrote :
Hi dj-in-norway
Probably would be enough to remove the mask part in the <coverart> code in the xml.
But i'll add some variants with square cover to the download asap ;-)
geposted Wed 11 Jul 18 @ 2:44 pm
dj-in-norway wrote :
[quote=VJ Python]Hi dj-in-norway
[/quote]
I did it this way. The result is the same. Edit xml do not know :)
geposted Wed 11 Jul 18 @ 2:54 pm
Sorry dj-in-norway, but I have another question.
How can I change the text in "current song" Blue-Dark Modern Arty [no remix - with coverart].xml
Thanks for your time!
geposted Wed 11 Jul 18 @ 4:55 pm
Hello friend - after download -install is successfull, I choosed type of video skins - but nothing to do....and all videoskins not work now
geposted Wed 11 Jul 18 @ 5:19 pm
Have you enabled the videoskin? Have you loaded and played a track whilst checking the video output?
geposted Wed 11 Jul 18 @ 5:21 pm
video skins are enabled
geposted Wed 11 Jul 18 @ 5:29 pm
a sorry- now is running - thank you :) supppeeeer
geposted Wed 11 Jul 18 @ 5:31 pm
Another question - How can I change the text in "current song" after edit in XML - nothing is happened - there is still current song text
and second question - is possible to set longer time visibility titler??
and last question - why sometimes is visible year of song - that is OK and sometimes not???? My format name of song is for exmple: Baby come back (1969) and this year between () sometimes is visible and sometime not I dont know why
thanks
thanks
geposted Wed 11 Jul 18 @ 6:26 pm
edit - current song - is running olee :))
geposted Wed 11 Jul 18 @ 7:51 pm
Why is the display messy code???
geposted Thu 12 Jul 18 @ 12:10 pm
Resolved ^_^The encoding is not UTF8.
geposted Fri 13 Jul 18 @ 9:04 am
it is famouse version titler ... I discovered where is possible to edit time to view of text...... :)
geposted Fri 13 Jul 18 @ 2:21 pm
VJ Python wrote :
[quote=dj-in-norway][quote=VJ Python]Hi dj-in-norway
[/quote]
geposted Fri 13 Jul 18 @ 9:32 pm
would be nice to have a choice of duration location of the title just like The TITLE that was built in VDJ last version
geposted Fri 24 Aug 18 @ 3:57 pm
Good work!!
I'm using this skin on 80's MTV style.
geposted Mon 12 Nov 18 @ 2:48 pm
It's possible to do but you have to hack the XML file.
I have mine set to come on after 45 seconds and stay live for 30 seconds.
geposted Mon 12 Nov 18 @ 3:07 pm
