badly no WYSIWYG editor for this :\
Yes Every part rely on each other
in a way to somehow work around this you can use placeholders and implement relation between elements
here one is 2/3 of total height and the other is 1/3
height defaulting to 144
of course same can apply to width and position i.e.:
notes:
1) shadow_bottom and shadow_end can be a <line>
2) instead of reloading a track to update you can disable and enable video again (using ctrl+V)
3) Take very care about math in skin:
operators do not have precedence and are computed before the next one
values are integer only and rounded at every step
i.e. :
1+3*3/8 ==> 4*3/8 ==> 12/8 = 2
3*3/8+1 ==> 9/8+1 ==> 1+1 = 2
1+3/8*3 ==> 4/8*3 ==> 1*3 = 3
3/8*3+1 ==> 0*3+1 ==> 0+1 = 1
<define class="titler_boxes" placeholders="height=144">and add a height to panel(s) calling it
<!-- shadow -->
<square name="shadow_bottom" color="#000000" visibility="10%">
<pos x="+6" y="+[HEIGHT]"/>
<size width="14+1400-6" height="6"/>
</square>
<square name="shadow_end" color="#000000" visibility="10%">
<pos x="+14+1400" y="+4"/>
<size width="4" height="[HEIGHT]+2"/>
</square>
<!-- boxes -->
<square name="red_ribbon" color="#e30613">
<pos x="+0" y="+0"/>
<size width="14" height="[HEIGHT]"/>
</square>
<square name="dark_top" color="#1d1d1d">
<pos x="+14" y="+0"/>
<size width="1400" height="[HEIGHT]/3"/>
</square>
<square name="light_button" color="#ffffff">
<pos x="+14" y="+[HEIGHT]*2/3"/>
</square>
</define>
<position y="900-[HEIGHT]/>"assuming declared skin is 1440x900, adjust to your needs
notes:
i.e. :
geposted Tue 07 Sep 21 @ 11:58 am
Thx @nicotux
Think I've got some idea to solve the equation here.
Using 1080p since it seems to scale down to the 720P anyway
geposted Tue 07 Sep 21 @ 3:18 pm
Rune (DJ-In-Norway) wrote :
Discussion about Title GFX 1
Thanks DJ-In-Norway for sharing your one of your masterpiece.
Cheers!
geposted Sun 10 Oct 21 @ 9:22 am
Hi Rune, thanks for this super titler. Question: Can I add the year of song to the titler, and what would be the code for it? It could be just in line with song name. Thanks
geposted Wed 16 Aug 23 @ 4:15 pm
Find the variant you want and add & " action="get_year"
geposted Wed 16 Aug 23 @ 4:20 pm
thank you!
geposted Wed 16 Aug 23 @ 10:07 pm
I'm looking to do something just a little Different. Would Like to show the Current song (Title, Artist, and one more field maybe Genre). AND the next song at the same time. This is the closest I've found. Any suggestions.?
geposted Wed 06 Sep 23 @ 12:56 am
Hello There!
Anyone have an idea on how to fade the incoming title and outgoing title when track changes??
Cheers
Fredrik/ DJ Needil
Cheers
Fredrik/ DJ Needil
geposted Mon 23 Oct 23 @ 1:21 pm
kamo_kaz wrote :
Good work!!
I'm using this skin on 80's MTV style.
How do you add the drop shadow on your text?
geposted Sat 20 Sep 25 @ 11:59 pm
How would I edit this to reveal the currently playing song Title & Artist? I'd like it to reveal after 30 seconds of playing time, regardless of where it starts playing from in the track. Thanks ahead!
geposted Wed 09 Sep 26 @ 7:53 pm
You'd have to write a timer with a RSI script, probably checking for only one deck playing and incrementing a counter, then have the reveal conditional on that counter.
I haven't looked at the xml for this skin but it could be done. I don't think there's anything in the skin currently that allows this without a xml edit.
About half an hour's work for somebody who can skin
geposted Wed 09 Sep 26 @ 8:09 pm
